Hot Rods ENGINE PING ( EGR , SPARK PLUGS)
Discussion in 'The Hokey Ass Message Board' started by fordstandard, Sep 5, 2018.
  1. fordstandard
    fordstandard
    Guys -- here is more info I found online. This is what a guy posted.
    1) His comment
    Pinging is caused by:
    Too high of a temperature in the cylinder. At about 2500 deg F. ping occours. The hotter, the more ping.
    ** This also creates a lot of NOx, which is what the EGR is designed to control. Many of our cars do not have or never had EGR valves.
    ** The heat range of the spark plugs makes a big difference. Too hot of a plug can cause severe ping to the point of engine damage.
    All spark plugs have various heat ranges. They all also have different internal resistance. The hear range will be by vehicle application, but the resistance is not.
    2) My next step to try to resolve - I will pull my plugs and try a different range than what is in there and see what happens
  2. bobss396
    bobss396
    First things with plugs, make sure they don't have any aluminum globbed on them. It may be detonating for a variety of possible reasons.
  3. sunbeam
    sunbeam
    Did you ever try sea foam or any type of top engine cleaner ? Carbon build up is probably the worse offender.
    Truckdoctor Andy likes this.
  4. noboD
    noboD
    Are you asking a question? Or just making a comment about pinging?
  5. Truck64
    Truck64
    from Ioway
    In most cases the stock, factory OEM plugs will be correct plug and heat range. High performance and modified engines need a cooler plug. You might need a slightly cooler plug if you have a hotter ignition.
  6. sunbeam
    sunbeam
    In an earlier post I suggested sea foam I wondered if he tried it. I had a daily driver that would start to ping about every 10,000 miles a can of top engine cleaner and it was good for another 10,000. I look for the cheapest-easiest fix first.
  7. noboD
    noboD
    Exactly, there are lots of reasons an engine will ping, or should I say a lot of things will cause an engine to ping. Carbon, timing, lean condition will all cause it.
  8. bobss396
    bobss396
    Not many cars here have an operating EGR valve on here and most likely run correctly, aka no combustion ping. You have a 305? Look up the correct OEM plugs for it, check against what is in the engine now.
    First thoughts always are incorrect timing, too-low octane and hot spots in the combustion chamber. We used to knock the carbon loose by running a trickle of water down the carb while its running. Any modifications made to the engine always have an impact one way or the other. I've seen tired engines with the guts pulled out of them ping badly even under low to moderate acceleration. Have you run a compression check?
  9. wbrw32
    wbrw32
    STOP BUYING CHEAP GASOLINE......
    Bandit Billy and bobss396 like this.
  10. bobss396
    bobss396
    So we work on another mystery without any clues... I'd go up an octane level just for the halibut..
  11. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    If you have vacuum advance and have it connected to ported vacuum, try swapping to manifold va***m and reset your initial timing.
  12. Timing and compression is what controls cylinder temps.
    High cylinder pressure creates high temps, the high temp creates NOx.
    High octane fuel means it has an increased capacity to suppress combustion in cylinders with high pressure.
    Truck64 likes this.
  13. Hook up a EGR And be satisfied.
  14. Beanscoot
    Beanscoot
    Rather than trust "what a guy posted" on the internet, try looking up detonation in a decent reference source.
    Old wolf likes this.
