Hot Rods engine rebuild
Discussion in 'The Hokey Ass Message Board' started by channel cat, Jan 17, 2009.
  1. channel cat
    channel cat
    how much cam can I put in my sbc 283 and still be streetable.
  2. Rich Rogers
    Rich Rogers
    Depends on if you're running a stick or automatic trans. Knowing that would be a good start on the question
  3. HotRod_Joe
    HotRod_Joe
    Personally, I'd put the whole cam in there. :D
  4. ken1939
    ken1939
    Compression, cam type would be two big factors. I.E. Pump gas. Dont expect 1000hp.
  5. HOT40ROD
    HOT40ROD
    from Easton, Pa
    If you are just looking for the sould of a wild cam. Go with the Thumper cam from Comp Cams. Nice sound and very streetable.
  6. buffaloracer
    buffaloracer
    from kansas
    It also depends on how old you are. I used stuff 40 years ago that I wouldn't even think of today. Think I've reached the "Grumpy Old Man" stage.
  7. Small Chevy's respond well to solid lifter cams and stick shift tranny's. If not you might as well leave the 2barrel on it!
  8. Pir8Darryl
    Pir8Darryl
    Your age?
    Street? Street-strip? Strip? Cruiser?
    Compression ratio?
    Manual or auto?
    Intake? Headers? Other engine mods?
    Rear gear ratio?
    Did you vote for tech month?
