Engine rebuilding prices...How Much?
Discussion in 'The Hokey Ass Message Board' started by 40 & 61 Fords, Feb 17, 2009.
  1. 40 & 61 Fords
    40 & 61 Fords
    I have a 352 ford engine that needs more work that I thought once i got it down to the short block. I'm trying to decide if i should do this motor, or look for something else. I'm just trying to get some kind of idea what I'm looking at to get the following done.
    Tank the block
    Bore it .30 over
    install new cam bearings
    Turn the crank .10
    Tank the heads and install hardened seats
    I don't need firm prices, just looking for estimates...especially from guys in the Minnesota area who may have a shop to recommmend to do the work.
  2. Hello 40 & 61 Fords:
    I own / operate an engine machine shop in Rochester, NY and specialize in FORDs!
    I can give you prices for comparisons to your local shops.
    I will list labor prices if you brought it to my shop all diss***enbled I would:
    Hot tank block clean $75.00
    R & R camshaft bearings and soft plugs $50
    Line hone main bores $150
    Bore / Hone 8 cylinders $150
    Regrind crankshaft $165
    Check big ends of rods $4.00 each
    Rebuild big ends of rods as needed: Add $6.00 each
    [pin bushings should be checked also]
    Valve job [diss,clean,grind valves and seats. $165 pr.
    16 bronze K-line valve guides $100
    8 hard exhaust seats installed $120
    We always use new stainless exhaust valves $12 each.
    Hot tank misc parts: pan,timing cover,valve covers, intake $75
    We always diss***emble the rocker shaft ***emblys and regrind the tips of the
    rocker arms. They must be done on a grinding fixture to get the correct arc.
    Almost always install new rocker shafts.
    Parts are a whole new posting but this should give you a close idea of labor.
    Matt
    Pro-Formance Specialties
    1115 East Main st.
    Rochester, NY 14609
    585-288-1499 / 8-5
