Engine rebuilding ?
Discussion in 'The Hokey Ass Message Board' started by Kustom55, Oct 7, 2005.
  1. George
    George
    For doing the head & main bolts get a quality, say Craftsman, 6 point air wrench sockets. they won't tear up like the Chinese junk does. If I'm going to store one I use moly grease (lightly) on most wear surfaces, main & rod bearings, cam, rocker arms- pivots, valve tips, push rod sockets, fuel pump arm & concentric, timing chain. Before firing it up index engine, pull dist. & prime up oil system w drill motor. Br*** freeze plugs are cheap insurance.
  2. screwtheman
    screwtheman
    Don't forget about DVD's and videos! You can rent them at TechnicalVideoRental.com.
  3. 51 pickem up
    51 pickem up
    from mosheim,tn
    if you have any misgivings about anything STOP AND ASK QUESTIONS.:confused:
    i just finished a 350 and used a chiltons manual theres a good section
    on engine rebuilding.
    al sisson
    mosheim,tn.
    p.s.
    also follow all tourqe specs to the letter.
    good luck with your rebuild and have fun.:)
  4. Scrap Heap
    Scrap Heap
    I took my time, read everything I could get my hands on and read it again. Talked to some of the mechanics at work, when ever I got srtuck I would hit them up. I helped out on my brother and nephews circle track cars (they were always rebuilding engines in the off season) so I took alot of notes.With the right tools and info you can do it.
