Hot Rods engine removal from model A
Discussion in 'The Hokey Ass Message Board' started by Oldsmobile Art, Aug 29, 2014.
  1. Oldsmobile Art
    Oldsmobile Art
    how do I remove the engine from a Model A?. I want to keep the transmission connected to it if possible.
  2. Chucky
    Chucky
    I found it worked best to remove the bolts that are holding it in place. I would rather help you, and not make fun of you, but you set yourself up.......
    Could you be more specific?
  3. tb33anda3rd
    tb33anda3rd
  4. Texas Webb
    Texas Webb
    Remove hood,radiator,shift,lever,torque tube,un bolt pull out.
  5. tfeverfred
    tfeverfred
    Yup.
  6. Post #4 nailed it but left out "rent a cherry picker". I like to pull the engine and transmission as a unit. It is straightforward. Have you asked for help from your local Model A clubs, the Harbor area club or the Orange County club? Also be sure to bag and tag everything you take off.
    Charlie Stephens
  7. Chucky
    Chucky
    Here's a photo of how I did it. The trans came out still bolted to the engine. image.jpg
    Hotrodmyk likes this.
  8. callcoy
    callcoy
    plumbid excellent response, I would add that the poster also log in on the Ford Barn for further support!
  9. Model A Gomez
    Model A Gomez
    Mostly right, disconnect the torque tube, the brake linkage, emergency brake, exhaust, remove the top of the ******, headlight bar, hood and radiator. Then you can remove the nut on the front motor mount on the bottom of the front cross member and the two bolts on each rear motor mount into the bell housing. The rear mounts will probably hang up and require some prying to get the motor out.
  10. tb33anda3rd
    tb33anda3rd
    start by draining all fluids
  11. MightyTim
    MightyTim
    You need a selection of hammers in varying sizes.
