Hot Rods engine restorer WITH CSL help?
Discussion in 'The Hokey Ass Message Board' started by sho1off, Apr 10, 2017.
  1. sho1off
    sho1off
    from Buffalo MN
    Anybody use this for gas in the oil pan,
    after fix the carb, drain the oil, and new oil and filter.
    old oil has bad stuff in it filter was plug up
    was a new motor and now what
    drop the pan?
    run it any way?
    re build? the motor
    suggesting??? i need help
  2. If you gas fouled your oil and were not running it until it lost oil pressure and toasted the main bearings chances are good that all you need to do it change the oil.
    if you lost compression then you may need to squirt a little oil down the cylinders to get it running again.
  3. sho1off
    sho1off
    from Buffalo MN
    it had oil pressure
    but it a lot of metal in the oil
  4. town sedan
    town sedan
    Snake oil, but buy it somebody has a boat payment to make.
    Metal in the oil? Time to open it up and see how bad it really is. Good luck.
    -Dave
  5. sho1off
    sho1off
    from Buffalo MN
    new motor
    no miles on it yet
    just had my shoulder repaired , no wrenching for 3- 6 months
    i cant open it up
  6. Torana68
    Torana68
    from Australia
    got a photo of what was in the filter?
  7. sho1off
    sho1off
    from Buffalo MN
    I will get it tomorrow
    I saved the oil
    I put some in paint stainer a lot aluminum
  8. pat59
    pat59
    What is CSL?
  9. metalman
    metalman
    New motor or not metal in the oil sounds like real bad news no matter what the cause. How much gas got in the oil? How long did it run that way? I just drained one that had close to a gallon in it (fuel pump was letting fuel in the crankcase), drained the oil, refilled it. Primed the oil before I fired it, all seems well but I didn't find metal in the drain oil, it had ran maybe 5/10 minutes with gas in it. Good luck.
  10. Blues4U
    Blues4U
    from So Cal
    If you can see metal particles in the oil, large enough to determine the metalurgy, the damage is pretty significant. Unless your viewing these particles under magnification, they are at least 30 - 40 micron in size, which is the limit of human eyesight. For guys like me, it's a lot larger than that, unless I'm wearing gl***es anyway. Whatever that snake oil has in it is not going to fill in 40 micron size wear damage.
  11. sho1off
    sho1off
    from Buffalo MN
    Old guy told me about engine restore with csl to put in oil was in Msra linechaser last month in The Word by chaplain Connie Warner
  12. sho1off
    sho1off
    from Buffalo MN
    I google
    engine
    Restore with csl
  13. You have metal partials that big. .......You'll need to tear it down.
  14. sho1off
    sho1off
    from Buffalo MN
    I'm done for the year
    out of work for 3-6 months
    no money no toys
    i google engine restorer w/csl but the motor is to bad for that
    tight motor, piston are pobabbly junk
  15. Torana68
    Torana68
    from Australia
    ok so don't go sit at the pub get into the shed and pull the sump off and show us a main and a big end bearing for a start :)
  16. tb33anda3rd
    tb33anda3rd
    new motor as in crate engine? or new motor as in "new to you"? new rebuilt?
    i seen ***embly lube that looked "aluminimy"
  17. upspirate
    upspirate
    Put the **** in it, what you got to lose? (sounds like you already lost the engine)
  18. sho1off
    sho1off
    from Buffalo MN
    is not that easy
    im 69 years old
    had a stoke 7 years ago
    i had to leand to spack
    i cant read or write very good
    commuting is hard for me
    8 week ago had rotate cup in my shoulder 3-6 mouths healing
    i had to learn how to fish and hunt
    doc said no wrenching for 6 months
  19. sho1off
    sho1off
    from Buffalo MN
    its not that eazy
  20. sho1off
    sho1off
    from Buffalo MN
    1969 ford 351w new but rebuilt,and rebuilt again long story, call me for details 763 283 1805
  21. I'm 71, this thread is making me feel bad!
  22. sho1off
    sho1off
    from Buffalo MN
    if i could i would take pan of see how bad bottom piston?
    motor is tight, ran they to beak the cam woudled tell how long
    351w with 302 cam so ran it runing on 4 cyl , yea the do that the cams until the figure out ,long story agine call 763 283 1805
    i wold drive it about 10 miles pull fiter and see how bad it is
  23. sho1off
    sho1off
    from Buffalo MN
    when you have to count youye guys in there 40's that dont know old suff and think know everything
  24. Torana68
    Torana68
    from Australia
    Maybe someone nearby that could drop around and help?
