Technical Engine Run Stand
Discussion in 'The Hokey Ass Message Board' started by 4 pedals, Nov 26, 2022.
  1. Some bellhousing are tough to find, I have one but never even crossed my mind I would be standing over it or beside it revving 3500 rpm ,there will never be another one on it again without a bellhousing and probably a metal fan shroud, should really have something over the fan belts too ,but what fun is doing things without a little risk LOL
    GlassThamesDoug likes this.
  2. Bangingoldtin
    I will send you some measurments tonite
  3. GlassThamesDoug
    GlassThamesDoug
    My relatives are from Brantford...
  4. Are they car people ?? One of the oldest car clubs around started in Brantford I believe , Piston Pushers
  5. I am sure there are a few Piston pushers on the Hamb and will correct me if I am wrong !!
  6. solidaxle
    solidaxle
    from Upstate,NY
    PXL_20221206_175142261.jpg Since I would only use one occasionally, I never wanted to spend the time to fabricate one. This thread has got me thinking, there are two old generator sets in my yard that have out lived their life expectancy. Both have heavy channel frame beams, v8 mounts, radiator, battery holder. I'm more then half way there.
    4 pedals, Tickety Boo, reagen and 3 others like this.
  7. GlassThamesDoug
    GlassThamesDoug
    Farmers.... Uncle had construction company, helped build race track near Caledonia.
  8. Hot Rod Dan
    Hot Rod Dan
    from Texas
    Mine is similar to one in an earlier post. It was important to be able to dis***emble mine and store it in a small space. I bought the plans for mine off evilbay and modified them for the material I had. I've also painted it since the first pics. It's been used for a 383 and a 468 build I did.
  9. Black Panther
    Black Panther
    from SoCal
    I just picked this one up...looks to have been built in the mid 60s. Uses a Hurst mount for the front and a cast iron bellhousing for the rear. Radiator looks like 50s GM. Has an 8 track player..chrome speaker grills on the side. Throttle is a lever with a valve cover T bolt to keep it in a certain spot. My plan is to clean it up and just have a display engine that can be started for ****s and grins...kind of like a garage cacklefest.
    57 Fargo and GlassThamesDoug like this.
  10. Waratah
    Waratah
    Here's mine I made during one of our lockdowns with my rebuilt Stude 259 mounted. Cheers Stu
  11. stanlow69
    stanlow69
  12. Paul
    Paul
    Editor
    that is the best one yet
    57 Fargo likes this.
  13. GlassThamesDoug
    GlassThamesDoug
    Rockin an 8 trrack ....
  14. Kan Kustom
    Kan Kustom
    Lots of clever ideas coming out here.
