Technical Engine runs extremely RICH?
Discussion in 'The Hokey Ass Message Board' started by seadog, Nov 26, 2022.
  1. seadog
    seadog
    OK, here’s the pooda.
    347 Ford; Brawler double pumper carb; Cam; headers; aluminum heads; MSD.
    New engine from a reputable builder…it runs good & the car is much quicker. BUT the plugs are nasty black and mileage is terrible. Recently the plugs were so fouled that it wouldn’t start. I cleaned them a bit and it fired right up. In an attempt to get it straightened out I have: gone down two sizes on the main and secondary jets (now running 68 primary/72 secondary. The fuel pressure is dead on at 6.5 psi, which is what Holley recommends. I put new plugs in it after making those changes, drove it almost 200 miles today and pulled the plugs. The attached photo shows how the new plugs look. What am I missing here?
  2. seadog
    seadog
    I forgot to say that I’m running 90 octane non ethanol fuel. The fuel level in the float bowls is half way up the sight gl***.
  3. AHotRod
    AHotRod
    1. Engine vacuum to low and opening up the power valve.
    2. Not enough ignition timing
    Deuces, sunbeam, 05snopro440 and 6 others like this.
  4. impala4speed
    impala4speed
    Wrong power valve? On my BBC with Comp Cam roller the vacuum at idle was less than the power valve rating allowing extra gas to flow. Did the same thing as yours. Changed power valves now it's good. Just something to consider. I'm ***uming the Brawler does have a power valve.
    Edit: AHotRod beat me to it.
  5. seadog
    seadog
    It has 36 degrees of timing.
  6. AHotRod
    AHotRod
    I'm referring to Initial-timing .... you have not provided the camshaft specifications, or id the ignition system is full mechanical, or vacuum ***isted.
    I stand by what I said before, the power valve is most likely the issue.
    Have you put a vacuum gauge on the engine while it warm and in gear (if automatic)?
    impala4speed, 19Eddy30 and mad mikey like this.
  7. RmK57
    RmK57
    Have you played around with the mixture screws? With a four corner idle an 1/8 of a turn on all four can make a big difference.
  8. seadog
    seadog
    I don't have the cam specs at the moment, I'll dig them up in the morning and post. Ignition is MSD plug and play distributor, full mechanical and was set up by the engine builder...tested on dyno.
  9. seadog
    seadog
    The mixture screws are set to factory recommendation...I'll see if leaning them a bit makes a difference, but they just affect mixture at idle, right? When going down the road under higher rpm they wouldn't have much impact on the mixture? At least that's what I have been told.
  10. pprather
    pprather
    No vacuum advance will cause it to run rich (not enough ignition advance) when cruising at light throttle.
  11. brando1956
    brando1956
    What's vacuum reading at idle? As two previous posters mentioned your power valve may be causing it to run rich if vacuum is low due to a bigger cam and power valve has a higher rating. Could also be a blown power valve. All it takes is one backfire to take it out. Have you checked the float level and verified the needle and seat and float aren't leaking?
    The amount of deposits on the plugs suggests a carb problem but you might take a close look at ignition as well, considering it wouldn't fire the plugs until you cleaned them. Good wires, cap, rotor, etc? Full 12 volts to MSD - not connected to OE resistor wire from ignition.
    Sounds like you had this running in the car before the rebuild and all was OK. Anything changed other than the rebuild?
    S10_Man and Kevin Ardinger like this.
  12. seadog
    seadog
    I'll put a vacuum gauge on it tomorrow. This is a completely new engine with less than 1,000 miles. The ignition system checks out in terms of voltage and installation.
  13. seadog
    seadog
    You may be on to something. I wondered why the engine builder used a non vacuum distributor, but since he came so highly recommended I didn't question him. I figured he would put the right springs in the distributor to make it work correctly. I need to get back to him and ask.
  14. KULTULZ
    KULTULZ
    Lloyd's paint & glass and X38 like this.
  15. '29 Gizmo
    '29 Gizmo
    from UK
    Check float level or sticking float valves
  16. FishFry
    FishFry
    For a race car it's fine, but for a street car you absolutely need a vacuum can for mileage, idle, cooling and drivability.
    Your total timing of 36 doesn't cut it, unless you plan to run WOT most of the time. Anything under 52 degrees (mechanical and vacuum full in) produces less than optimum fuel economy and response at cruise speed. Depending on fuel, compression, cam and a few other factors, it may even take up to 58 degrees.
    And no - you can't make up with springs and weights. Mechanical and vacuum are two systems that work hand in hand and correct each other, based on RPM and load . If you loose the vacuum, you loose the load hand.
    Here is some reading for you, that explains it pretty good: https://www.crankshaftcoalition.com/wiki/images/e/e4/Vacuum_Advance_Specs.pdf
    Also - looking at your plug, it seems way too cool for what you got. But I would first fix your vacuum situation and deal with stuff the other guys mentioned (power valve/fuel levels etc.) before you try other plugs.
    Side note: IMHO fuel level is way overrated and to some degree a myth - but that's a whole other can of worms.
    Frank
    Jagmech, jaracer and AHotRod like this.
  17. mad mikey
    mad mikey
    Your timing must be set first to were the engine is happy, you have to find the sweet spot. Then you can tune the carb. I agree with Glenn, check vacuum and install the correct PV. Tuning is a process. A air /fuel ratio gauge can be your friend here, getting you on the right track during the tuning process. Take your time and make one change at a time.
    Deuces, Tickety Boo, AHotRod and 3 others like this.
  18. 19Eddy30
    19Eddy30
    from VA
    Like others posted ,
    800-1000 rpms Idle , ( Some engines like more)
    The engine will let you know what it likes .
    ""Initial timing"" more likely be 15-20 average, some engines like more.
    Vac gauge for adjusting mixture , & point to witch pv needed ,
    You have to start Tunning @ idle
    ( idle rpms , initial timing , mixture screws )then work from there ,
    Plug heat range will be another tunning procedure,
    Deuces, AHotRod and mad mikey like this.
  19. 19Eddy30
    19Eddy30
    from VA
    Also a good Quality O2 gauge will help Cruise to wot carb tunning , reading plugs with modern blends of fuel off pump is miss leading, Look @ modern OT tail pipes ,
    (Black & Study) Here in N Va there is only a few suppliers selling non-ethanol fuel, (some Wawas & Farm Royal some Sheetz) it seems to not be consistent, it looks contaminated to have a white ish tint like water present, or lube.
    mad mikey likes this.
  20. Moriarity
    Moriarity
    SUPER MODERATOR
    yup power valve, do your eyes water when you stand behind it when it is idling? also the fuel in the bowls should be at the bottom of the sight gl***, you should have to bounce the car a little to see it. If you are at the middle of the sight gl*** you may be covering air bleeds with fuel.... I agree with vac advance for fuel mileage you need to have 50 or so combined degrees adv at light throttle freeway cruise
  21. pprather
    pprather
    With the electronic ignition, plug gap can be opened up to.040 or .045" to reduce fouling.
  22. whateverit takes
    whateverit takes
    from Florida
    Is this the same carb the builder used to tune it on the dyno?
  23. bschwoeble
    bschwoeble
    Is this a racecar? Is it truly a double pumper (mechanical secondaries)? If so, just for grins, disconnect secondary accelerator pump and take it for a spin. Or is it a Holley with vacuum secondaries.
  24. mad mikey
    mad mikey
    Pretty sure the Brawler Holley carb is mechanical secondary.
  25. 2OLD2FAST
    2OLD2FAST
    from illinois
    Maybe 10%..
    Mileage Depends more on load/ throttle opening , does the vehicle weigh 2000 lbs or 6000 lbs , do you drive up & down hills , stop start traffic , steady cruise rpm ?
  26. KULTULZ
    KULTULZ
    ... hmm ... flip ... flip ... flip ...
    Well, I guess they changed that since the seventies ...
  27. 2OLD2FAST
    2OLD2FAST
    from illinois
    Actually in some cases , they have . Plus , these are m*** manufactured , which means there's room for error .
    Lloyd's paint & glass likes this.
  28. TA DAD
    TA DAD
    from NC
    With center hung floats the best way is when you have the bowls off, flip them upside down and set the float so it is hanging level and you are good to go.
    Deuces likes this.
  29. seadog
    seadog
    Yes
  30. seadog
    seadog
    Lots of ideas to investigate here. I’ll be busy for a while.
    To answer some of the other questions, car is a Deuce roadster with manual transmission; it weighs 2470# without driver and half a tank of gas. It’s not a race car…I was hoping for a faster street car.
    When I put the new plugs in about a week ago, I started it and let it just idle for about 5 minutes…pulled a couple of plugs and they already had a fine coat of soot developing. Once I drove it at speed it only got worse. Maybe I just need to switch to a vacuum distributor? I should hasten to add that while I’ve been messing with cars for most of my adult life there’s a WHOLE lot that I’m still learning. Appreciate all the answers and help here.
    2OLD2FAST likes this.
