Engine Steady Rods
Discussion in 'The Hokey Ass Message Board' started by FTreadway, Oct 17, 2013.
  1. FTreadway
    FTreadway
    Does anyone know if there were several different lengths of engine steady rods made? I have a '39 1/2 ton with a '46 239 engine. I have 3 sets of steady rods and all 3 are too short. One set is about an inch longer than the other 2 sets. The longest set is 12 3/4" from the front of the flange back to the center of the screw hole. These are still a little over an inch too short for the engine/frame setup I have. I cut one set and welded in a sleeve to get the correct length. Figured I could use this setup until I found the right length, if it exists.
