1954 235 going in a 1950 3800 with a 216. will the bellhousing/ flywheel/ clutch from the 235 bolt up to the 1950 ****** without any modifications? i have heard alot about the 235 bolting up to the 216 bellhousing set up, but the flywheel and clutch are rebuilt on the 235 and i would like to use them if at all possible. motors get swapped starting tomorrow hopefully!
Yep.it all fits. The front mounts won't work without transplanting the '54 side mount towers to your frame, or welding a mount onto the '54 front cover to fit the stock '50 mount.
