History Engine swaps of the past.
Discussion in 'The Hokey Ass Message Board' started by Carolina Man, Oct 28, 2013.
  1. Carolina Man
    Carolina Man
    I remember reading in the late 40's people use to swap in engines from Caddies, Chrysler,Olds into their 40's era cars. I have been thinking of dropping in a Chrysler 440 into my 48 Chevy instead of the usual SBC. Any idea's on this subject?
  2. 1971BB427
    1971BB427
    from Oregon
    In 1968 I dropped a 413 Chrysler with 727 trans into my '40 Chevy coupe. Had to eliminate the inner splash pans on the fenders, and a fair amount of floor work to redo, but it wasn't a bad fit. Should be even easier in a '48.
  3. Carolina Man
    Carolina Man
    I bet that was a wild ride.
  4. 1971BB427
    1971BB427
    from Oregon
    Yeah, it also had an early 50's Chevy truck straight axle, and the rear axle from the Chrysler in it too. Was a handful when I got into it, but at 18 yrs. old I figured if it didn't scare me it wasn't any fun! ;)
  5. snaptwo
    snaptwo
    Why not ,make a sleeper out of that 'ol bowtie . A guy I worked with put a 392 in a '51 chevy , didn't last long as he blew a tire at speed and wadded it up on his way to the "cat house" in Nye county. He and the '92 survived .
  6. 26 roadster
    26 roadster
    70 Camaro w/ 440, 727 and 8.75 rear. Had to build pan and pick up.
    If your going to sell it stick with the status quo
  7. 1971BB427
    1971BB427
    from Oregon
    Absolutely! I love oddball swaps, but when it's time to sell, it sure reduces the buying audience! Somebody will always be offended by a swap that isn't considered traditional.
  8. '51 Norm
    '51 Norm
    from colorado
    I put a 421 Pontiac tri power into a '62 Studebaker Champ pickup.
    At various times I had a Saginaw 4 speed, a Muncie or a TH400 behind it. Did I mention that I had transmission troubles?
    Scary fun anyway.
  9. Carolina Man
    Carolina Man
    It would be a sleeper to a point, I was always taught to use what I have. If I do this then it's a keeper which I planned on doing anyway.
    I was curious to hear what people have done in the past and problems they run into.
  10. benjamin j
    benjamin j
    So if you were reading this stuff in the forties you are probably to old to be driving anyways. :D
  11. Carolina Man
    Carolina Man
    Yep my gums are older than my teeth.
  12. k9racer
    k9racer
    in the late 50s and early 60s if you had a car with a bad {not good}engine you would swap in what ever you could find. A example was 352 V8 Packard with auto transmission in a 52 ford. Countless trucks and cars with any thing that you could find cheap..
  13. Carolina Man
    Carolina Man
    I wonder how hard would this be to do in a 48 Chevy.
  14. JeffB2
    JeffB2
    from Phoenix,AZ
  15. JeffB2
    JeffB2
    from Phoenix,AZ
    Since your '48 had an engine with a rear sump oil pan the swap will be easier if the donor engine is rear sump,click on this:http://www.440source.com/oilpans.htm the part # 100-1064 is a rear sump for 440 Mopar read the foot notes.Other rear sump engines are SBC's,Olds 330/350/455 and Pontiac 350/400/455, AMC 360/401 and 5.0 Fords fox body and later.The first book I listed above has a chart showing all the measurements and weights,downside of the big block Mopar is it is the widest across including manifolds at 29 1/2",SBC is 26",302/5.0 & 351W Fords are 22" something you want to keep in mind for steering box clearance you can get a rear sump pan for 360 Mopars http://www.summitracing.com/parts/rnb-264-232/overview/make/dodge and they are only 25" wide. :D Somehow the idea of a 351W in a Chevy really makes me grin! :D
  16. squirrel
  17. choptop40
    choptop40
    built ran a 413 out of a 63 imperial in a chopped and channelled , fenderless 36 buick , with the push ****on shifter mechanism installed on the dash , ran friggin sweet.
  18. 48jeep
    48jeep
    My Dad swapped a 232 stude v8 into our 48 jeep station wagon when I was a kid. Then when I came of driving age the 232 was replaced with a 259 v8 four barrel. This was my high school driver. Lot of fun.
  19. Tim McBride
    Tim McBride
    from Missouri
    I remember my dad and uncle putting random engines in stuff. It was never about what was cool or rare, it was whatever got them the cheapest horsepower.
  20. 63comet
    63comet
    My told told me about literally swapping a Falcon V8 engine with a Volvo engine. Took the Volvo drag racing and kept the Falcon on the road.
  21. I had an off topic Datsun 240Z someone had dropped a 351 Cleveland into, that went like hell!
    Did a 460 in a 48 stude pick-up.
    Other than that I always stayed with same brand, just seemed easier
  22. 1971BB427
    1971BB427
    from Oregon
    Not sure if it's still around, but I've got an old paperback book ***led, "Peterson's Complete Book of Engine Swapping" (or something like that?) It shows dozens of different engines swapped into all sorts of cars. I bought this book new in the late 60's or early 70's, and have referenced it often over the years.
  23. 1971BB427
    1971BB427
    from Oregon
  24. 63comet
    63comet
    I've got something along those lines in my archives! It's mostly big engines into smaller cars. Maybe the same manual? I can't remember the ***le but I remember part of the blurb on the back was "build your own supercar". It was a HRM special I think? It was printed same as a magazine and it was all reprints of magazine articles.
    My father used it as a reference source when putting the 327 (only Impala 327 ever switched into a car, much rarer than the 'vette engines everyone else used, lol) into his 1957 OT fast swoopy record setting body.
  25. Rickybop
    Rickybop
    Welcome C.M.
    I'm all for unusual engine swaps, but you'll have a clearance issue between the stock steering column and the rear of the p***enger-side head with any big-block engine. So either use a small-block engine or plan on modifying the steering, or mount the 440 high and/or biased to the p***enger side.
    Rear-sump oil pans and p***enger-side starters make things a little less difficult.
    Good luck.
  26. rocknrolldaddy
    rocknrolldaddy
    I put '59, 318 Poly in, after pulling a 241 Hemi out of my '54 Dodge Royal. There hasn't been much fabricating except for mounts and a bracket to operate the p***ing gear. Its not on the road yet. Ask me how its going in about a month :)
  27. fatkoop
    fatkoop
    Put a 364 Nailhead and T85 3-speed in my '56 Ford Victoria in the early '60's. Put early Hemi's in almost everything you can think of. Buddy of mine had one in his '54 Chevy, another buddy put one in his '57 Chevy. Cads were really popular in lots of stuff and so were Olds'. Lots of Y blocks in early Fords were common when I was a kid.
