Technical Engine transplant
Discussion in 'Traditional Hot Rods' started by texas77, Nov 26, 2013.
  1. texas77
    texas77
    from Texas
    Putting a small block Chevy in a stock body 1939 Ford sedan using a Chevy to an early Ford transmission adapter, will the wish bone need to be split?
  2. no , you can do that without splitting the wishbones
  3. texas77
    texas77
    from Texas
    Thanks for the info.
  4. fatkoop
    fatkoop
    No need to split the bones. Mine in avatar has a '62 283/adapter/stock trans and rear. Stock radiator with two holes blocked off. If you use a Hurst front mount you don't even have to drill a single hole. Convert to 12V and you're off and runnin' in a weekend.
  5. hammeredcoupe
    hammeredcoupe
    from Tacoma,WA
    did you use the stock flathead radiator with the smallblock?
  6. USA Tires Sign Joe
    USA Tires Sign Joe
    from Western NJ
    Hurst was way ahead of his time with all the engine mounts and adapter kits!
  7. manyolcars
    manyolcars
    Yes. The radiator shop can plug off the unwanted outlets. If you are asking if it works as far as heat transfer, Oh Yes! The flathead put out more heat than a smallblock
