Projects engine unsticking question
Discussion in 'The Hokey Ass Message Board' started by captainjunk#2, Apr 25, 2011.
  1. OahuEli
    OahuEli
    from Hawaii
    Hell I'm subscribing just to find out what stuck it! Never heard of using water though. Thats one reason I like the HAMB, you never know what you'll learn.
  2. captainjunk#2
    captainjunk#2
    i think 2 cylinders were at tdc and the intake valves were opening and moisture drifted down and into the cylinders , the lifter gallery is still oily and the exhaust ports dont have rust or a lot of carbon in them ,the intake p***age under the carb was clean , i read an earlier post were the transmission pump seal had locked up the drivetrane , the crusty old automatic is still bolted on to the engine , im going to remove the transmission and see what happens , id be some happy if it turned over
  3. Strange Agent
    Strange Agent
  4. flamingokid
    flamingokid
    Water is great in small amounts for cleaning out the cylinders (while running),but I've never heard of waterlogging a motor to unstick it.There's probably a direct correlation between this little factoid and all of the Project Cars(major peeve) that end up in the cl***ifieds.
  5. blt2go
    blt2go
    water will work to loosen rust. i've thrown many rusted upper links and turn buckles in the stock tank for a week or so to free up. haven't used it on a cylinder.
  6. 71buickfreak
    71buickfreak
    from Oklahoma
    I like to use JB80 from Justice Brothers. It works better than anything I have every used, inclubing kroil.
  7. Engine man
    Engine man
    from Wisconsin
    You know it's twice as good as WD 40!:rolleyes:
  8. 71buickfreak
    71buickfreak
    from Oklahoma
    If you have ever used it, you would know its true! I had a 51 Ford and I was pulling the motor. The bolts were rusted on so tight I broke a breaker bar trying to get it off. I sprayed it with JB80, let it sit 5 minutes and it came right off. Only other lube that I know is that good is astroglide....
  9. captainjunk#2
    captainjunk#2
    undid the bolts and the transmission and the bellhousing pulled right off , engine still didnt budge , going to take off the torque convertor and try a bar on it , if that doesnt work i will take it apart ,
