Customs Engine Vote 1948 Pontiac Streamliner
Discussion in 'The Hokey Ass Message Board' started by bgreene30, Apr 25, 2015.
  1. Small block
    56.3%
  2. big block
    25.0%
  3. 1956 Desoto Hemi
    18.8%
Multiple votes are allowed.
  1. Moriarity
    Moriarity
    SUPER MODERATOR
    these threads confuse me...coming up on 2 years since the original post, and we never heard what happened with the car. Did he ever put an engine in it? if so what?
  2. gnichols
    gnichols
    from Tampa, FL
    389 / 421 with tri power and the most modern automatic that will bolt up. Gary
  3. Mid 60's Pontiac OHC 6...had one in my 40 Pontiac...fit like a glove, and went like hell...
  4. Get the Hi-Po version.
    It was in the LeMans Sprint
    It had a 4 barrel and I think
    higher compression.
    Those OHC's could rev!
  5. bgreene30
    bgreene30
    Hi everyone. It's me again. So to update everyone. In hindsight I should have pulled that hunk of cast iron and swapped it out with a Pontiac v8.
    Needless to say I'm a softie for the old motors that you don't see much so I dumped 6k into the rebuild which included 2 sleeved cylinders and everything +060. dropped it all back in and low and behold we are baffled.
    It dumps antifreeze into the back three cylinders.
    Two head gaskets later we still cannot figure it out.
    Head was magnafluxed no cracks
    Block was pressure tested (wonder how they do that. Better ask)
    Head was decked and mated to block all in spec
    Had thread sealeant and the head bolts
    We did not apply any other sealeants to the head gasket as the gent at Pontiac parts said if you need that it's a sign of something else off.
    About ready to ghost dive it off the nearest cliff.
    Any ideas?
    Help
  6. 73RR
    73RR
    I'll ask the obvious...did the shop guy sonic check the cylinders before boring to 060?
    And, which holes were sleeved?
  7. falcongeorge
    falcongeorge
    from BC
    Too late now I guess, but I would have done a 389/400 Pontiac. Its a HUGE, HEAVY car, torque is your friend, and another very big factor in its favour is that Pontiac motors are not as popular in the traditional hot rod world as Olds, nailheads or early cads, and because of that, I notice vintage speed equipment for Pontiacs is in less demand, and a bit cheaper than the traditional "big three".
  8. So, you still have the original problem from '79.
    Shame too. Those Poncho straight 8s could pull trains and last hella long time.
    It'd be a helluva crack in the block to bridge all 3 cylinders.
  9. vtwhead
    vtwhead
    where are the sleeves in relationship to the leaking cyls? What is the machine shop's position with regard to all of this?
    For 6 grand someone ought to be doing something for you!
  10. bgreene30
    bgreene30
    They're working on it and covering the costs.
    Seems we're going to Copper coat the gasket which we've been installing dry.
    Sleeved cylinders are 2/7
    A gent that worked at Eggie Machine said the head gaskets need To be coated. At this point. Whatever works. Should have slammed a new plant in the beast. Hindsight.
    koolkemp likes this.
  11. RichFox
    RichFox
    I am no expert here. But I do like to put compressed air into a cylinder to see where it's getting out. Sort of like leak down test. If water is getting into the cylinders I guess air could get out. This would tell you if it was a head gasket leaking. I don't know if a Pontiac could leak water from the intake into the cylinders. Maybe there
  12. silverstreak48
    silverstreak48
    I’ve been thinking about swapping out the straight eight for a 350, was it a huge process?
  13. silverstreak48
    silverstreak48
    Old post but does anyone that’s done a v8 swap in a 1948 Pontiac know the configurations for motor mounts?
  14. Hnstray
    Hnstray
    from Quincy, IL
    you have answers on your other thread.
