Hot Rods Engineering nightmare
Discussion in 'The Hokey Ass Message Board' started by Kiwi 4d, Dec 30, 2025.
  1. theHIGHLANDER
    theHIGHLANDER
    Anyone wanna do an egghead calculation and figure out how many pounds of force go thru steering? Think about a 2800lb car hitting a hole, a bump, or an unavoidable obstacle at 40 MPH. Or, how about an emergency maneuver at a freeway speed? Rolling down smooth blacktop at all times isn't realistic is it? If one considers such things during a build, is that too much worry? Just sayin, and I don't care how nice it was notched or that they sell such stuff. Not me...
    Rodney Dangercar and twenty8 like this.
  2. NoelC
    NoelC
    I believe there is a vast amount of knowledge offered on the HAMB. And some real opinion fueling it.
    And I do respect that, I just happen to disagree.No harm no foul.
    How about you measure the end of your old Ford pitman arm, a tie rod diameter, the stud on a ball joint, the U Bolts? Ge whiz, it doesn't take more explanation. I have yet to see a matching part without a groove posted yet here we are. How about this picture, tensile test. You really need to suggest the gloom and doom that would cause even modern cars to have part failure and breakage?
  3. willys36
    willys36
    I won't tell you about the brake swing arm mounted to my plywood firewall on my Willys, made from the stamped sheet metal running board bracket off my frame. 17yrs old when I came up with that great idea!
  4. gene-koning
    gene-koning
    There is no wonder not many hot rods are getting built these days, everything has to be approved by the safety comity. We can't do anything our selves, it has to p*** engineering first.
    Above all, don't post pictures of anything you do, or pay to have done, on your ride, unless you have the proper ***le or certification that says you can do such things.
    I jest, sort of.
    Clydesdale, 2OLD2FAST and Wanderlust like this.
  5. blue 49
    blue 49
    from Iowa
    I hit an unavoidable obstacle (a car that turned in front of me) with my right front tire of my 2500lb truck at less than 40 mph. This was my GM Vega box after, as well as quite a bit of other bent steering/suspension parts.
    Gary
  6. X-cpe
    X-cpe
    My grandfathers take on building things for other people. If you build it twice as strong as it needs to be, it will last half as long as it should.
  7. gimpyshotrods
    gimpyshotrods
    Factor in the length of the steering arm, and ***ume that everything else is immovable.
    Over one meter, in 2-miliaseconds, that is 201,272.5715 pounds of force.
    That is roughly 100-tons.
    Put that steering arm in a 100-ton press, and see what you get.
    Put it on a car, and you could get dead.
  8. twenty8
    twenty8
    That comment pretty well explains why you have the opinion you have.‍:confused:
    Hitting a pothole on a crowded highway at 60-70 mph could add more stress to the part than you think, and the consequences could be horrific.
    Really easy to make the right decision at build time than to deal with a bad decision when it is all too late. It's called "taking responsibility for your actions".
  9. Ziggster
    Ziggster
    Can argue all day if it was “good enough”, but as most have stated, not the preferred approach that should have been taken. As a mech Eng, I can approve this though. lol! Some real attention to detail there.
  10. Hot Rods Ta Hell
    Hot Rods Ta Hell
    The Super Bell arms are drop forged and are not notched for a zerk. It's safe to say they did not (over) design the part manufactured size to 200% to accommodate for an end user to notch them.
    https://www.summitracing.com/parts/...DfrniufDmuQEJOFC_oYE_i04WvX-zx7X8-RN_UxFf8o_h[/QUOTE]
  11. HOTRODPRIMER
    HOTRODPRIMER
    I very well may scare easy, I was involved in an accident on a 1956 Harley-Davidson, the bike looked good and I thought the builder did a first cl*** job, but he did some sketchy work on the springer front suspension parts, 60 MPH is the wrong time for something to break, I have a gimp leg due to something being modified and it weaked the part, thus I ended up in the hospital, fortunately not Forset Lawn.
    I would have changed the part just like the OP did. HRP
  12. theHIGHLANDER
    theHIGHLANDER
    The run-to figure in my imagination was like 10 to 20, but I think the point is made.
    @blue 49 I think that sector shaft has a lot to say too. It isn't fear to consider **** like this, it's smart. And above all it's responsible and disciplined. These aren't go-karts with Maytag motors in junior high. Just sayin...
  13. NoelC
    NoelC
    Starting somewhere...
    You pull that out of a hat? Quote a source for those numbers? What are you trying to say exactly, could you explain what you said for some of us that didn't quite understand it? I mean, it doesn't take 100 ton to bend that arm, flatten it most likely, 50k psi will; do it.
    [/QUOTE]
    Ok, that's cool, but I don't see dropped forged I see a cast part. Cast steel and machined. I say that because the Super Bell lettering appears to be raised and I see casting marks. No matter, you showed a reproduction part and we were previously shown another repo part with notches in them? That just means a little more work if you must dis***emble to add more grease I guess?
    Springer front end, 60 miles an hour...let me guess, one of those give it a triple tree neck rake and extend the fork length? Sorry for your limp. But what does it prove, buddy who built your bike couldn't weld or he ground a part excessively and you paid the price? How old were you at the time? Was there any booze or drugs involved? Running the interstate or back roads of small town USA? Relevance is what I was getting at past you paid the price for sketchy back in the day.
    And to clarify, the OP changed it because he switched sides with his steering and then he questioned its fitness and condition for service.
    I think 10 to 20 is still a bit on the high side, but hey, seems it's as good a guess as any in this conversation.
    And while we aren't talking go carts and maytag motors, the sensible discussion should follow along the lines of what's the calculated force required and being placed on the arm, and the surface it mounts to as well the bolts holding it in place.
    So...do we need a bigger steering wheel or a smaller one so we don't exert as much force? One or the other has to make it safer don't you think? Or should we just weld it up, grind it off and remove the zirk? Would that be better, be enough? Safe to use? If you didn't know would it hurt you?
    Anyone keeping score on who would or wouldn't use it? Because if we are taking a tally, I would. My opinion hasn't been swayed by your opinions or fearful beliefs.
    Anyhow...Not my job to convince you. Believe what you want.
    badshifter likes this.
  14. gimpyshotrods
    gimpyshotrods
    No.
    I spend 12-years in Engineering school to be able to do these calculations in my head.
    My work has been trusted and verified by numerous major manufacturers, and even more minor ones.
    I am not telling you how much force it will take to bend that damaged arm. I am telling you how much force will be exerted on it, under the requested conditions, at the peak of the impact.
    As you have gathered, it is substantially higher than what would take to cause it to fail.
    It is an order of magnitude higher than the peak guess.
    Oh, and The Buddha never said that. That is an example of confirmation bias, which is universally accepted to be flawed thinking.
    5window, GuyW and Rodney Dangercar like this.
  15. RICH B
    RICH B
    Instead of basing your opinion on an advertising picture; take a look at the second picture of the first post; pretty plain to see by the wide parting line and stamped in brand name that SB arms are forged as advertised.
    Anybody with any sense would address the zerk issue in a different manner than that notch.
  16. Rodney Dangercar
    Rodney Dangercar
    I see something like this notch and what I actually see is a job that was done by someone with tunnel vision and one goal, get it done and fast.
    Regarding the notch, is the part thru forged?
    gimpyshotrods likes this.
  17. NoelC
    NoelC
    Far be it for me to question someone who spent 12 years in Engineering school, but I'm not intimidated by it either or rather enough to not say, "show me the math equation and calculation and what information you used to come to that conclusion". And with all due respect, nor will I bow down and kiss the ring if that's what you think should come from providing it.
    As for the words of Buddha, no he didn't actually say that. But it fit, it was questioned.
    Google "did buddha say believe nothing quote".
    Instead of? That is the one being commented on because it was used to show us, or show me, one without a notch. Also, I would expect, even suggest, that what the pictures shows is what you actually get to buy these days. And from the Speedway picture, it doesn't appear to be, nor is it advertised that it's forged. Forged being a stronger product, the OP picture showing a indented logo stamping, sure, call it forged. The Speedway one, I'm not convinced it is.
    As far as sense goes, common or otherwise, I still don't see it as a point of extreme concern. There is at least an equal amount of material as there is in the diameter of the bolt anchoring it. And the original shows no sign of deformation to suggest movement.
    In regards to a different manner, would a 90 degree zerk instead of the 45 degree zerk and a smaller notch make a difference? Or leave it out, no groove slot or notch, plug the king pin grease hole and call it greased for life being the only solution that's going to make sense? Everybody happy?
    41CMTNPykxL._SX342_SY445_QL70_ML2_.jpg M10-x-15mm-Grease-Fitting-90-Degree-Stainless-Steel-Zerk-Nipple.jpg
  18. willys36
    willys36
    Static strength is still pretty good for sure. However this is a dynamically loaded part so fatigue becomes a consideration. Fatigue strength considers stress being applied, removed, applied, removed, etc. over time. This strength is much less than static strength. That becomes even more problematic when you put a notch or reduction in cross section in a fatigued part. Stress is calculated as pounds of force applied to square inches of cross section or PSI. Reduce the cross section of a part and the stress concentrates at that point. The ultimate worst design is a shape with a sharp step in cross section. A sharp step has zero area so stress approaches infinite PSI!! The notch in the subject part has a large radius which is good. But if it was cut with a grinding stone and not polished, the scratches from the stone have zero area so there would still be a dangerous stress riser in that area.
    All that being said, that part is probably ok, should get you to Sonic Drive-In every Saturday night and back home for the duration.
  19. willys36
    willys36
    Bad designs come from manufacturers too. One common modification on a popular hot rod front axle, not to be named, is to eliminate a strut rod included in the original factory design. This strut rod is considered ugly on a street rod so some companies sell designs without the support. One of my personal tasks when attending rod runs was to point out cracks in the suspension on guy's cars due to using strut rod eliminators.
    gimpyshotrods and GuyW like this.
  20. willys36
    willys36
    Not quite apples and apples. The modified part has an unsupported stress riser in the form of a full cross section notch. The other part pictured has a notch but is more ****ogous to a hole drilled in a frame than a notch cut in a frame. The notch is bordered by a 'flange' that can absorb most of the dynamic stresses, ****ogous to the flange on an I-beam or the flanges on a C-section frame rail. Holes cut into the I-beam or C-section center plates do not weaken them appreciably.
    I still would try to come up with a solution that didn't reduce the cross section of that part!
    gimpyshotrods and alanp561 like this.
  21. theHIGHLANDER
    theHIGHLANDER
    Ok, I'm gonna bring the milk crate/coffee/garage echo mood back into this.
    @NoelC is declared the biggest ****. His unwavering dedication to "...**** it, get it done..." is notable. It is without doubt he deserves the COB certificate (crabby old *******s) in this ¼ of HAMBdom for 2025. The cert states, "We the unwilling seen by the unknowing, are preaching the impossible to the unfaithful. We've said so much about so little for so long, we're now qualified to say anything about nothing."
    May these words ring true a****st the parts and aromas in shops and garages everywhere.
    [Suddenly the compressor stopped and Joey wasn't grinding. Freddie and Zack had the part, one sez "...well it IS part of the steering so..." and they were walking back to the axle. Just then a faint bell rang in the distance, a sound akin to an Asian ceremonial gong. Shop was quiet for a moment. Hank farted loudly, Jack says "Dammit Hank, your voice changed but your breath didn't!" Lee says "Hey, sounds like he's still a virgin!" The shop erupted in laughter as Lee was ready to fire up his coupe. The universe was in balance again.]
  22. Ziggster
    Ziggster
    Engineering (at least in Canada) is likely the only profession that does not require you to be licensed. The only engineering field you were required to have a licence was civil engineering. Although I obtained my licence (Professional Engineers of Ontario), and had it my whole career (30 plus yrs), I was never required to have it to do any “engineering”.
    leon bee and Sharpone like this.
  23. HOTRODPRIMER
    HOTRODPRIMER
    Sharpone likes this.
  24. HOTRODPRIMER
    HOTRODPRIMER
    Noel, you seem to ***ume a lot, the builder of my bike was not my buddy, the neck on the frame was not altered in any way and the springer front end was stone stock, what it proves is that someone that lacks the knowledge to try and modify a bearing can get you killed, taking a part that has met all the criteria required to manufacture said part.
    When a bearing locks up on the front wheel of a motorcycle wants to turn but the bearing and spoke are being ripped out and the bike ang goes into a death wabble.
    Why does it matter how old I was but to satisfy your
    curiosity I was 24 at the time and there was absolutly no drugs or alcohol involved and I was on a back road on my way home from work. HRP
  25. patsurf
    patsurf
    :p:p:p:p:p:p great way to bring this back down!
    warbird1, theHIGHLANDER and Sharpone like this.
  26. Hot Rods Ta Hell
    Hot Rods Ta Hell
    [/QUOTE]
    @NoelC, Good eyes. It appears as though the steering arm in current vendor ads is cast (probably ductile iron) as it has a thin casting line and raised lettering. Ad description states: "• Aftermarket and Super Bell spindles only. • Works with Super Bell Mustang disc brake kit, stock 1939-48 Ford brakes. (All parts for this kit are in chrome) Will work with stock 1937-48 Ford spindles.*with grease fitting modification*"
    https://www.affordablestreetrods.com/super-bell-slingshot-arm-chrome-1017-c.html
    The SB and aftermarket spindles have the zerk holes angle drilled for clearance. When I read "grease fitting modification", I think 45 or 90 zerks, as I mentioned in post #53.
    Whereas, @Kiwi 4d lead photo shows an apparent forged casting (wide seams, stamped lettering).
    While searching steering arms, I came across a HAMB thread posted 5 years ago, ironically by @Kiwi 4d:
    https://www.jalopyjournal.com/forum/threads/super-bell-steering-arms-forged-or-cast.1189010/
    The consensus on that thread was that those arms were forged. So possibly manufacturing has morphed from forged to cast? A call to P&J's may net some clarification.
    Either way, IMHO, no steering component (cast or forged) should ever be severely notched for clearance.
  27. 5window
    5window
    Man, I love "I'm inside cause it's winter" Mondays!
    leon bee and theHIGHLANDER like this.
  28. gimpyshotrods
    gimpyshotrods
    I have 33-years of do***ented results, specifically in preventing death, injury, and catastrophic expense.
    You have bluster
    If you want to question me, come prepared.
    Your at***ude serves no positive purpose.
  29. Paul
    Paul
    Editor
    and of course drama is sure to close a thread.
    clem, badshifter, hotrodA and 5 others like this.
  30. gene-koning
    gene-koning
    The concern over the forged and notched part seems to be the biggest concern about this ride.
    The picture above shows at least a few things (the S bend in the steering link would likely bend more at both bends, or could break the ends off the tie rods, the multi bolted steering arm on the box would probably fail, and possibly the box mounts themselves), that would likely fail long before the forged piece becomes a problem, especially in a crash.
    Replacing all the questionable parts would be the smart thing to do, but the starting point would be to address the worst case things first. The forged part is not the worst thing shown on this ride.
    AccurateMike and GuyW like this.
