Technical Engineering question, a serious one
Discussion in 'The Hokey Ass Message Board' started by 31Vicky with a hemi, Mar 7, 2018.
  1. Yes exactly.
  2. bchctybob
    bchctybob
    If the factory does it that way, it's most likely because it's safe enough - and the cheapest way.
  3. nunattax
    nunattax
    you could speak with kugel komponents they sell an underdash brake ***embly.heres one modified a little [​IMG]
  4. bchctybob
    bchctybob
    Sooo, have we solved the perfect pedal problem? Or was it pushed to the back burner?
  5. Waiting on a few parts for a new idea.
    Heavier shaft, solid welded ***embly, non serviceable bushings, entire ***embly, pedal arm, pivot, and MC lever bolts on the outside of the frame rail. Probably way over built and gorilla on a bulldozer strong. Sleeping better.
  6. Gotgas
    Gotgas
    from DFW USA
    "The safety of steel, from toe to wheel!" ;)
  7. mgtstumpy
    mgtstumpy
    Personally I'd have a larger surface area in the brake pedal boss area and have a longer 3/4 36 boss that fully engages both sides of the pedal with welds on each side (Double sheer).
    Sent from my SM-G950F using The H.A.M.B. mobile app
