Technical Engineering types, I have a question about air cfm
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Jan 4, 2023.
  1. Budget36
    Budget36
    Can you plumb your compressor to a storage tank, then work off it?
  2. Roothawg
    Roothawg
    I looked into a second tank, but most real aux tanks are extremely expensive. I have looked on FB Marketplace for an old compressor with a bad motor. A bigger line would be easier.
  3. Roothawg
    Roothawg
    2OLD2FAST and Tman like this.
  4. Dustin 257
    Dustin 257
    from Dallas
    you have to remember the tank size really doesn’t matter that much. It gives you stored energy but the compressor has to be able to keep up with demand.
  5. Roothawg
    Roothawg
    So, if it acts as stored energy, would the larger piping act the same?
  6. lake_harley
    lake_harley
    Larger pipe = less restriction.
    Less restriction = higher flow with less pressure drop through the pipe.
    Larger tank or larger pipe does have more storage capacity but it cannot make up for a compressor that's too small for the quan***y of air needed at a given pressure. Part of the purpose of a larger tank is to keep the compressor from cycling on and off and on and off and....... A larger tank can also serve a high demand for air for a short time but eventually the "storage" is gone and you'd be operating at the CFM the compressor could put out at a particular pressure where the system would eventually "even out". My old compressor was way too small for a blast cabinet. It would only maintain about 40 PSI if used continuously. My larger compressor will maintain ~90 PSI at the compressor tank outlet (hose connection) which is enough for my blaster to work satisfactorily. The "piping" is a regular 3/8"(?) 25' long air hose.
    I've seen the recommendation that a good pressure piping system would make a loop around the perimeter of the area it serves. That gives two directions that air can flow to any given point where air is used in the loop.
    Lynn
    Dos Cincos and Roothawg like this.
  7. Roothawg
    Roothawg
    My goal is to try and maximize the efficiency so my compressor and the blast cabinet work at their peak. I think the CFM will not really be an issue. Just tuning it up a tad.
  8. Budget36
    Budget36
    I understand that.
    I dump my 25 gallon into 60 gallon tank when use my cabinet. It gives me about ten minutes or so before the little compressor kicks back on. Let’s me take a break, pull the part out and look it over, etc. then I chill till it fills the big tank back up and the compressor shuts off. Rinse and repeat. Maybe I’m too patient, but I really don’t want to be staring into a cabinet for an hour straight;)
    NoelC likes this.
  9. theHIGHLANDER
    theHIGHLANDER
    Oh ****, here he comes again...:rolleyes:
    Anyways, were you having any issues with the smaller cabinet, as in waiting for pressure, volume, etc? I peeked at what you're considering. I'm going to ***ume this is so you can do bigger parts, not have 2 blasting ops in the same cabinet. If that's the case then plug in the big one and have at it. Optimum doesn't always mean needed. Volume, pressure, CFM, all ratings to ****yze. What are YOU doing? If it's the same in a bigger cabinet and you always did just fine...?
    For the science faithful in the audience I too would tee off ¾ and send it leaving the ½ "behind" the source feed. You need a ¾ tee at the compressor to hook the flex gig to undisturbed and make your home run to the cabinet source. Maybe I'm being Capt Obvious...?
  10. Roothawg
    Roothawg
    I think that’s what I will do. I am going to add a 3/4” Tee right after the flex line. Run a dedicated line to the cabinet. This should eliminate any issues.
    As far as my present blast cabinet, it works ok. It was a used one I picked up off of CL years ago. It’s pretty small. I need more room for bigger parts.
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    I have this TP skat blast 960. Might not be the same because it is not a foot pedal unit. My air lines are 1/2” and it is about a 50 foot run from the compressor. I can blast as long as I want without a problem. you can't see it in the pic but I use hydraulic hoses for my flexible connections, I have 1 on the compressor, 1 on my tire machine, and 1 on my blast cabinet
    alanp561 likes this.
  12. Roothawg
    Roothawg
    The difference is mine isn’t the Limited edition, white lightning series. I just got the old regular series cabinet. All the cool kids get the cool stuff…
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    haha duh, when I bought it this was the one that was on sale..... have had it for almost 20 years, really like it. I have done larger than the cabinet parts by leaving the door open and taping a plastic tarp over the opening, less than ideal but it worked and I don't have room here for the giant cabinet....
    Roothawg likes this.
  14. lostone
    lostone
    from kansas
    My brother used an old water heater tank out of his house. Worked great.
    2OLD2FAST and Roothawg like this.
  15. Roothawg
    Roothawg
    I thought about it, but the corrosion and the max pressure kinda worried me. With that kind of volume and it decided to let go, it could do some major damage.
    On that vein, a friend used a 1000 gallon propane tank and buried it in the back yard behind the shop. He said the worst part was getting rid of the oil residue left over from the propane. He doesn't paint though, so he wasn't worried about fisheye.
  16. gimpyshotrods
    gimpyshotrods
    My entire shop backbone is made of 3/4" lines. The pressure wash, and bead/sand blast cabinets are the 3rd and 4th thing after the compressors (we run two). Both are 40" from the compressors, on the other side of a sound deadened wall.
    Both compressors have timed drains at the bottom, that release any water that has collected, opening for 1-second, every 15-minutes.
    The first thing after the compressors is a 1-1/4" self-draining water trap, oil trap, and regulator (we run 120psi in the backbone, and local regulators for each tool area). The two compressors are tee'd together before it.
    The second thing after the compressors is a refrigerated dryer. We only run the secondary when the primary is down, or being serviced, or am going-to-town with the DA while the CNC is running a tool change heavy job.
    Both cabinets are plumed without QD's, with lines that exceed the diameter of they have onboard.
  17. 2OLD2FAST
    2OLD2FAST
    from illinois
    Since the supply lines are effectively part of the tank , they are part of the storage .
    The only pertinent sizes are the blaster valve & orifice .
  18. rpu28
    rpu28
    from Austin
    Gotta go with Tman on this: maybe what you have will work just fine. There are way too many variables to search for an ****ytical answer.
    If you are not pleased with the performance of your easiest set-up, start making changes, beginning with the cheapest and easiest.
