Technical English wheel mods
Discussion in 'The Hokey Ass Message Board' started by grdra1, Aug 14, 2022.
  1. grdra1
    grdra1
    After finishing my bead roller recently, next up was my English wheel, a few pics. Glen 20220805_152319.jpg 20220805_153941.jpg 20220805_153948.jpg 20220805_153952.jpg 20220810_141328.jpg 20220810_165610.jpg 20220814_171814.jpg 20220814_171839.jpg 20220814_171849.jpg
    harpo1313, Okie Pete, Nominal and 5 others like this.
  2. billfunk29
    billfunk29
    from Minnesota
  3. NoelC
    NoelC
    I'm going to give you points for effort, but as far as design and functionality, not so much.
  4. hrm2k
    hrm2k
    It might be over kill but that doesn’t matter. Flex should be almost nothing at all.
    I have a wheel from a different company. I don’t use mine often but when I do, I am always fighting flex. I see a lot of ideas for mine
  5. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Quite a nice shop you have there, and a nice job on modifying your English Wheel! There is one thing I'd add to it..............kinda the "icing on the cake" so to speak. Since it appears you have some type of overhead crane set up, I'd put an "eyebolt" on that top flat spot for easy lifting with a crane or forklift. Great job...........
    Okie Pete likes this.
  6. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Please explain.
    X38 likes this.
  7. NoelC
    NoelC
    Well I think it appears a bit ***bersome. Not well balanced, somewhat top heavy.
    It's modified design doesn't flow smoothly in my opinion. It appears added on to as a after thought not as a compliment to the original design. I'm sure however it's stiffer and less twist prone if your wheeling a ball peen dented bumpy sheet with bravado and some gusto.
    Not saying mines the end all to that, but it is of a simple enough design isn't it? It can be easily modified if need be to adapt for... a deeper depth per say. Following the original design, I'd have wrapped the original with that tube, just wrapped it differently.
  8. TRENDZ
    TRENDZ
    I think it’s a great change that will benefit final use. It doesn’t look like space is a concern, so the added bulk is a non issue.
    The throat depth doesn’t limit you nearly as much as the other unit in this post. Great execution of improving a good tool.
    ekimneirbo and Okie Pete like this.
  9. NoelC
    NoelC
    With all due respect to the man for actually doing something to make improvement, there was no harm or foul intended to that end, just one man's opinion on what was done in execution of the idea to do so.
    A good designer is trained to refrain from the compulsion to add. The objective of good design is to reduce; reduce the amount of parts, reduce complexity, reduce waste, and reduce cost. Design is the ability to make clear a product or services purpose or message.
  10. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Noel, this is the Hamb and part of the world of Hot Rodding. Adapting, modifying and wretched excess whether it improves anything or not......is the rule of the day.:D
    Building one from scratch is different from just trying to improve an existing tool. I think both of you did a good job. I've got a Harbor Freight one that I may modify someday. Probably try to use existing metal I have ac***ulated. The price of raw metal has gone thru the roof. Really difficult to get any steel cheap enough to build projects these days. Like I said, I think both of you did a good job.:)
  11. NoelC
    NoelC
    I whole heartedly agree. I agree so darn much it's why I posted what I did. The next guy hopefully won't think it couldn't have been done a slight bit differently, made better for less. Material and effort.
    I gave the man credit for having done it. It was a lot of work there is no doubt about it. But so you know, when I built mine I did look around to see what beefy materials I had and that rectangular tube was what I had. Only thing wasted was the miter cuts. About 7' long if memory serves. And I also thought if I need to increase the depth in the future, it will be easy to do.
    I'd ask the question, if our friend had did the sides before the top and back would it have been done at all?
    ekimneirbo likes this.
