English wheel
Discussion in 'The Hokey Ass Message Board' started by Hrodblack, Jan 22, 2007.
  1. Hrodblack
    Hrodblack
    Does anybody have blueprints on building a english wheel or know where i can find some?
  2. dana barlow
    dana barlow
    from Miami Fla.
  3. Unkl Ian
    Unkl Ian
    Lot's of English Wheel info on www.allshops.org
    Do your research before copying,or buying,Junk.
    The Harbor Freight POS is discussed here in a seperate thread.
    The basic layout isn't too bad,but the frame is not stiff enough,
    the material is thinner than advertised,parts are sloppy,wheels wobble,etc.The usual Cheap Imported ****.If you have the means to fix that one,you can make a better one from scratch.
  4. tisdelski
    tisdelski
  5. John_Kelly
    John_Kelly
    Hi Gary,
    Why pick just one when there are two with lots of great information? I am a member of both. They both have their strong points.
    John www.ghiaspecialties.com
  6. I'm in the process of building the one listed on roddingroundtable & plan to report back. Carl Hagan
  7. hammeredabone
    hammeredabone
    I purchased a kit from Ron Covell some years ago, built the frame to his specs and used his tensioner and upper wheel brackets. at that time it was $1200 plus about $175 for the frame material. Has worked very well, definetly worth the money.
