Projects Enough monkeying around: let's build a 5w, or another 4dr bites the big one.
Discussion in 'Traditional Hot Rods' started by thunderbirdesq, Dec 22, 2011.
  1. Chris
    Chris
    Wicked dude!
  2. thunderbirdesq
    thunderbirdesq
    firewall recess mockup... Bent up some 18ga panels, rolled a few beads in them, and tacked them in. the pedals don't hit it and I can still pull the distributor... mission accomplished. Just gotta weld it up and add a flange along the inside lower edge for the toeboard to sit on and bolt to.
  3. Pete
    Pete
    Man, you're cruising right along.....looks great.
    Pete-
  4. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Looking good Andy!! It's gonna be nice all week in Buffalo so we're all expecting some major updates through out the week. I think you need to get about 2 boxes of 36 grit rolocs so you can smooth out those ramhorns and either have them chromed or jet coated black......or you just paint them I suppose.
    Did that trick you guys used on Jim's firewall no allow for enough room?
  5. Noland
    Noland
    looks good. I like it. keep up the awesome work
  6. thunderbirdesq
    thunderbirdesq
    Yea, they're a little raunchy, but they'll have to wait for now... The lower section of this firewall was so chawed up it had to be replaced anyhow, this just seemed easier. Plus with the yblock dist WAY in the back there I need a little more room I think.
  7. HomemadeHardtop57
    HomemadeHardtop57
    Andy,
    I found that small barrel sanders work great for the nooks and crannies
    or carbide bits
  8. bobj49f2
    bobj49f2
    I like these for little areas and inside round holes but they tend to leave some little sharp slivers, the kind you don't find until you touch something :eek:
  9. thunderbirdesq
    thunderbirdesq
    Yea those carbide bits work pretty well but they also throw a **** ton of tiny, HOT, sharp, chunks around. I always worry about my eyes when using them. Jerry those sanding rolls look like they might work good, gonna grab a few of them. I got a small 90* die grinder with some 2.5" grinding wheels that works pretty well, just out of wheels.
    I think I'm gonna make a steel toeboard like 33-34 pickups have and skip the wood...
  10. 550Coupe
    550Coupe
    You only have one set of eyes Andy. Safety gl***es, face shield, gloves and hearing protection. There's your safety lecture for the day.
  11. thunderbirdesq
    thunderbirdesq
    You're not kidding Art, I have had to get metal pieces removed from my eyes a few times... it's no fun. The last time I dug the little ******* out myself... I'm so paranoid about it now, I check my eyes out first thing when I come in from the garage. Occaisionally I find a little chunk down in the corner under my eyelid that I didn't even know was there!
  12. justabeater37
    justabeater37
    I have gotten metal dug out after the rust ring formed too. Misery at its finest. I now use Eyegogs as I have had stuff bounce off of the inside of my safety gl***es and into my eye. Build looks awesome by the way. I wish I could get myself out to the shop to work on my heap more.
  13. kwmpa
    kwmpa
    from Pa
    you know me im always safety first...i get metal in my eye all the time...it **** just glad that piece you got in you eye at my house you were able to get out without a trip to the doc
  14. thunderbirdesq
    thunderbirdesq
    yea that one was more like a CHUNK, hahaha!
  15. hillbilly4008
    hillbilly4008
    from Rome NY
    Yeah, gotta love it when your chins in the cub and they are coming at your eye with this friggin mini-drill with a wire brush attachment telling you "Now don't blink"
  16. hotdamn
    hotdamn
    you know if youre using a carbide bit run it through some gulf wax first and it doesnt through such big slivers and most importantly it lengthens the life of your bit!!!
    and andy, as per usual, youre killin it bro!!!
    I cant get over that this is the same clapped out 4dr jj and I picked up in Nov!!!
  17. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    And to think we almost lost the body on the thruway because we were going to put the body on cinder blocks on the trailer. If that would have happened we would have just kept diggin'!!!! It was operation Dank Nugs if that happened!!!
  18. hotdamn
    hotdamn
    hahaha! I forgot about that:D
    and JJ, dont hate on those ram horns too bad, they could be in worse shape!!!
  19. TomT
    TomT
    Looking really good - I still can't believe this was a 4-door at one time - just unreal!
  20. thunderbirdesq
    thunderbirdesq
    Firewall welded up/braced... I used some 1x2 16ga tubing to shore the cowl up here, I'll use some more to tie this brace into the A pillars which will also be reinforced... no cowl shake here.
    floorpans are goin in... I sliced a piece of the aforementioned tubing lengthwise and hammered it flat in the appropriate areas that it crosses over the frame/Xmember/TT (keep in mind that the trans is currently an inch higher than it will be when bolted in and the TT will be a few inches lower once the QC is installed) I don't *think* I'll need a tunnel but we'll see.
    Stock floorpans have a recessed bead that follows the X member, I 'm just going to use a die set I made to depressed a round spot around the floor bolt holes in that area. Stock floors also go UNDER the subrails, these are going to be welded on top.
  21. bobbooth
    bobbooth
    from limeyland
    Cool dude,glad to see you making more progress
  22. Mopar Jack
    Mopar Jack
  23. chopo
    chopo
    [/QUOTE]
    theres a bunch of 10 dollar words in that paragraph
  24. thunderbirdesq
    thunderbirdesq
    Howsabout this 10 dollar word? ****in-a!
  25. chopo
    chopo
    that is actually priceless :) good job bud
  26. McFly
    McFly
  27. Flat-Foot
    Flat-Foot
    from Locust NC
    Looks killer. You sir are a ruler!!!
  28. Blammo!! Wicked pissah!
  29. thunderbirdesq
    thunderbirdesq
    Thanks doods, Needs the front spring eyes reversed...
  30. Cshabang
    Cshabang
    looks good Andy!!!
