Projects Enough monkeying around: let's build a 5w, or another 4dr bites the big one.
Discussion in 'Traditional Hot Rods' started by thunderbirdesq, Dec 22, 2011.
  1. ynottayblock
    ynottayblock
    looks and sounds killer, great job dude
  2. Don Moyer
    Don Moyer
    nice job saving a 4 door!
  3. Outback
    Outback
    from NE Vic
    Thanks for the vid, it's very cool to see this thing alive!
  4. F&J
    F&J
    Ah ha, see? you questioned me when I said I wanted smaller lights on mine.:rolleyes:
    I agree the parking lights on top are so Y2K.:D
    I had some nice small ones over 40 years ago on a 50s built car, but I sure don't recall if there was a brand name. Painted bucket, chrome or stainless rim. The buckets were not as pointed.
    and small tail pipes are what it should have, so you get one attaboy
  5. thunderbirdesq
    thunderbirdesq
    I'm not against the signal on top, per se... or the size really, I just wouldn't want anything larger. I just want some old lights. :eek:
  6. F&J
    F&J
    No old truck junkyards nearby? That's where you will find some.
  7. thunderbirdesq
    thunderbirdesq
    There are a few... but most of them have crushed all that era stuff out and what's left is picked over pretty hard or rotted into the ground. :(
  8. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Greta job! The car screams Hot Rod. I can't believe you busted this out in such a short amount of time, all the while having a great at***ude and not taking time away because you "got stuck on a certain point of the build and needed to take a break" like most of us do on builds.
    How many hours do you estimate you have into it?
  9. kisam
    kisam
    Holy Smokes Andy - that's exciting! So happy for you! Hey the charging part, I couldn't tell from your pic of your voltage regulator but it kinda looked GM? Anyway here's a pic to be certain and a good article to check it out.
    http://www.vintagejeepparts.com/PDFs...REGULATORS.pdf
  10. Hearing that thing run made my day!!!
    Awesome job Andy. Now put some miles on that bad boy!
  11. el Roach
    el Roach
    Just too f*cking cool. Nice.
  12. n847
    n847
    Damn...Congrats...Again...Your a machine!
  13. thunderbirdesq
    thunderbirdesq
    THanks, I'm not sure how many hours, I didn't really keep track... figure about 2-4 hours a day a 3 or 4 days M-F and probably 6-12 hours a day most but not all sat and sundays since Dec.
    Thanks Kathy, yes it's a GM regulator, and a beat up old ford generator. I'll check out the link and see what's up.
    That's the plan Dave! Thanks bud!
    Thanks fellas!
  14. Hitchhiker
    Hitchhiker
  15. Malcolm
    Malcolm
    from Nebraska
    Unreal man... you are kicking *** on this thing. I can't believe it is already running and driving -- way to go!!
    Malcolm
  16. kisam
    kisam
    Andy, I tried to use a Ford regulator with an Autolite(Chrysler) generator and it wouldn't work. I think they have to match. As soon as I robbed an autolite regulator off an old motor - it started charging. Took me forever to figure it out.
    I want to see a driving video - you can make it when your pretend sleeping!;)
  17. That thing sounds great! I'm giving you the slow clap right now. Bravo! Oh and x12 on the driving video...
  18. ArchangelKustom
    ArchangelKustom
    from NR/OH
    Have you tried polarizing the regulator?
  19. Uncle Jess
    Uncle Jess
    from Western Ny
    Andy man looking great, I would really appreciate it if guys like you and Tony would each have a couple few kids and slow down on these killer builds! I am getting envious!!! hahah Looking great man keep it up.
  20. hotdamn
    hotdamn
    wow...
    really, I can't think of any other word that conveys...
  21. Retribution
    Retribution
    from Western PA
    I agree on the headlight, something old sounds right. Yes please, more video!
  22. F&J
    F&J
    I meant Big truck and "earthmoving equipment" junkyards. I've seen cool old style lights on stuff all the way into the 60s...even on old roadgraders and tractors, needle nosed Peterbuilts, Autocars, etc.
  23. S.F.
    S.F.
    DANG Man! RADNESS .............You drove yours before I got to drive mine :D ...I need to quit slackin!
  24. Chris
    Chris
    That thing looks awesome and sounds great! I can't wait for guys to ask you where you got it, and you reply "Jeffrey James thought it was too far gone, so I bought it and had it running/driving in a couple months". Would it be a lie?????
  25. davo461
    davo461
    Top job Andy, that really is the cats pajamas !
    Would any old tractor or machinery work lights do the job?
  26. shiftervic
    shiftervic
    from So. Cal.
    It turned out pretty nice Bud!
  27. thunderbirdesq
    thunderbirdesq
    Thanks guys! Headlights are taken care of, my good pal Millersgarage is gonna swap me these for some BLC's!! Thanks Jeff!!!
    :D:D:D:D:D:)
  28. davo461
    davo461
    New pics when it's done, please.
  29. thunderbirdesq
    thunderbirdesq
    Did a bunch of stuff today... Installed the rear shocks. Hooked up the e-brake and got it operational. Greased the rear wheel bearings up while I had the hubs off... I hope these last a few thousand miles until I get the QC under there, the ****ty bearing surfaces on the rear cones have me a little spooked... Adjusted the valves which were making a bit of clatter, some were tight some were loose, all dialed in now. Changed out my leaky brake light switch and adjusted the brake linkage again, pedal feels GREAT now. Made some small exhaust baffles to allow oneself to think and see straight while sitting in the car with it running. Figured out my charging problem and fixed it. Installed a 13lb cap which in turn made a radiator leak apparent where I blocked off the hole from switching the inlet over to the driver's side... grrr, if it ain't one thing... at least it's on the top side so I think I can solder it up without pulling the radiator.
    Going to the DMV tomorrow to get plates!
  30. Chemin
    Chemin
    That's so awesome. Nice to get a bunch of smaller things done than little progress done on big issues. Can't wait to see it in person.
