Enough
Discussion in 'The Hokey Ass Message Board' started by al-uminum, Jan 7, 2010.
  1. al-uminum
    al-uminum
    What should the distance from firewall to front spring center on a '32 be?
  2. speedtool
    speedtool
  3. LIL.TIMMYUser Name
    LIL.TIMMYUser Name
    my 29 measures 48 inches. does this help?
  4. al-uminum
    al-uminum
  5. Deuce Roadster
    Deuce Roadster
    The distance will vary depending on where you measure the firewall. A BETTER measurement is from the spring center hole to a hole that the firewall bolts to. That distance is 32 inches.
    You can see in the photos below, there are three holes for the firewall ... the 32 inch measurement is for the second middle hole ( the frame has a small dip in it there :) ... or at least original frames do ;)
  6. al-uminum
    al-uminum
