Epoxy Primer Still Sticky
Discussion in 'The Hokey Ass Message Board' started by Camm, Aug 19, 2012.
  1. Camm
    Camm
    After 4 hours in the sun??????????? It has never done this before. Any help ??:confused:
  2. Don's Hot Rods
    Don's Hot Rods
    from florida
    How old is the hardener ?
    Don
  3. Camm
    Camm
    2 years
  4. go-twichy
    go-twichy
    it could still be fine. the stuff i use takes about 6 to 8 hours before i start to want to play with it or move it in.
  5. CRH
    CRH
    from Utah
    I am no pro, but my Valspar LIC epoxy primer (which is a little old) takes a while to dry/cure. It seems like I always forget how it stays wet WAY longer than sanding primer, and I spray it regretfully thick just to find runs and sags about an hour AFTER it looked fine. I guess because it is such high solids I keep foolishly treating it like build primer and spray it too thick. Then, because it stays wet for so long, I get aftershock drips.
  6. Moonequipt13
    Moonequipt13
    Not to question your skill set, but are you sure you mixed at the correct ratio? The reason I say this is when I started painting I had hell of a time deciphering the mixing cups :D. Other than that, the only thing I can think of is too thick of a film build, but even then it should at least be handslick by now. What kinda primer you using?
  7. Camm
    Camm
    Dtm kustom shop
  8. Camm
    Camm
    Still tacky.
  9. ty johnson
    ty johnson
    Has the product stayed in a above freezing area. Even at that, it can still go bad.
  10. Engine man
    Engine man
    from Wisconsin
    If it hasn't cured by tomorrow, call your paint supplier. I don't even like to think about stripping epoxy primer.
  11. afaulk
    afaulk
    Well, if it hasn't hardened, lacquer thinner or MEK will wash it off.
  12. how long did you let the epoxy sit after mixing? ALL epoxies i have used have an induction period .this period ranges from 15min. up to 45min depending on temp .what does the tec sheet on the primer say?
  13. Camm
    Camm
    It Cured..........Finally
  14. herbet99
    herbet99
    from Central NJ
    wow.. that'll test your nerves
