I sprayed a bed side with KustomShop epoxy primer surfacer/sealer. It uses a reducer to spray it as a sealer. I sprayed one side one day, and the other side another day. One side is twice as shiny as the other after using as a sealer. My question is how did I make it shinier? Does adding more reducer make it like this. Im assuming I goofed some how mixing the sealer.
Yep, ya goofed up on your reduction, over reduction of most epoxy primers will produce a very shiney finish. Sand & reshoot using a mixture of uniform reduction shot at the same tempture and pressure. " Meanwhyle, back aboard The Tainted Pork "
