Equus gauges
Discussion in 'The Hokey Ass Message Board' started by scoop, Aug 6, 2011.
  1. scoop
    scoop
    Anybody using them?The 7000 series is good looking and reasonably priced.
  2. Motornoggin1
    Motornoggin1
    They are ok, considereing their chinese lineage. I think I would still rather have Autometer or maybe a good set of vintage SW guages.
  3. edweird
    edweird
    yep i used them in my old coupe. i like that SW vintage look for cheap.
  4. Scoop, I have looked at em here in town. Considering the issues guys have had with the newer IMPORTED SWs I see these as being as good if not better.
  5. Gator
    Gator
    from Statham Ga
    O'Reilly's carries them, I used a set in a build a few years back, worked OK.
  6. I bought a full set of 5 gauges with new ignition and lights switch off of Craigs list for $100 . All new including the speedo. They look vintage but don't expect them to be all metal.
  7. scoop
    scoop
    I kind of figured they would be plastic.Kind of like the idea of the ring that screws on the back of the gauge for mounting.Parts City here in town has them,they give me a discount cuz I spend alot of money there.
  8. el Scotto
    el Scotto
    from Tracy, CA
    They'll match those Chinese "1950 Pontiac Style" tail lights perfectly! Hahaha!!
    Moedog07 likes this.
  9. scoop
    scoop
    You mean 59 Caddy,get it straight!haha
  10. AAFD
    AAFD
    from US of A
    Walmart carries Equus. I don't buy my car parts from Walmart.
    sidevalve8ba likes this.
  11. Berky
    Berky
    I'm the Product Manager for all the gauges and most of the tools. I'm bugging upper management for a more traditional looking line :D
    Yes, the gauges are Chinese, but they work well and if you have a problem our customer service will take car of it. (or you can let me know)
    Mike
    Driver50x and vtx1800 like this.
  12. MORRISGAUGE
    MORRISGAUGE
    Nothing made today is of the quality craftsmandanship of your vehicle's original gauges. Most aftermarket sets are basically the same, but you should definitely expect to pay for quality. Do it right the first time and go with a company that will be able to provide replacements in the future.
  13. Unlike many of the builders here, I actually prefer electronic speedometers and gauges. When I looked at the Equus they did not have what I wanted. Has that changed?
  14. Thank you for chiming in and listening to our needs.
  15. Just like 95 % of all reproduction parts even though they are US Companies , still made in China. The sign of the times.
    abe lugo likes this.
  16. Berky
    Berky
    In the 7K series, which is what most of us would prefer out of the three lines, the only electric is the water temp. I'm with you on the electric gauges, they are just as reliable and so much cleaner to install. I put a set in my Model A, but I had our QC make me an electric oil gauge:D
    Threads like this are something that I can present to management to help push our lines and give the people what they want.
    Thank you,
    Mike
  17. Fenders
    Fenders
    I got the $25 fuel gauge from rebusan (ebay ID) -- well worth it. I too like the screw-on back ring, easy to mount. And I like the LED back-lit dial.
    I had a problem with the first $16 one I bought (sender ohms mis-described) but he solved that issue quickly. Sorry if this seems like a plug but he is one of the good ebay seller.
  18. I want that dinky size that is avail. in the 8000 sreies done in a traditional black like the 7000!
  19. el Scotto
    el Scotto
    from Tracy, CA
    At least the 1959 Caddy lights LOOK like 1959 Caddy lights.
    Compare a REAL 1950 Pontiac taillight to a "1950 Pontiac Style" one. You'll see a lot of differences. You can spot the chinese ones at car shows from twenty feet away.
    It would be like buying a poster of Marilyn Monroe and receiving one of Rosie O'donell.
    The anatomy is the same, but in reality they're really different.
  20. scoop
    scoop
    Thanks, now every time I see a Marilyn Monroe poster I'll think of Rosie,yuk.
  21. nummie
    nummie
    My tach started on fire right on my steering column, driving down the road. Scared the **** out of me, almost caused an accident while I tried to pull over and put the flames out. This brings up another point, buy a good fire extinguisher!
  22. Kevinsrodshop
    Kevinsrodshop
    These Equus gauges are available at Canadian Tire for those in Canada. For economical gauges they'd look alright in your dash.
  23. johnboy13
    johnboy13
    I was running their Ford fuel gauge and a volt gauge. Had no problems whatsoever. Only reason I switched out was because I found a complete set of early Econoline gauges that I swapped in.
  24. 1971BB427
    1971BB427
    from Oregon
    I put the 7000 series gauges in my Austin g***er when I built it. Got speedo, fuel level, oil pressure, water temp and volts, all for under $135. I like the old style look and the mounting ring. They work great, and can't beat that price, as others were more than twice the amount.
  25. johnboy13
    johnboy13
    Oh yeah, the mounting ring. Pure genius.
  26. ochamsrasor
    ochamsrasor
    Used them in 5 projects, never had a problem. I do not have a problem with "Gucci" look alike, saves money and makes money and never had to replace one.
  27. caprockfabshop
    caprockfabshop
  28. abe lugo
    abe lugo
    NO shame in using something to get by and upgrading later (Im doing this one some gauges as well, using Bosch gauges). But have some SW waiting once everything is done and confirmed.
    If its a temp gauge check with an IR gun to see that it reads right, just double check things.
  29. MMM1693
    MMM1693
    Scoop, Put a mechanical water temp 7000 in my 40. So far it works great running in the shop.
