Technical Evans heads inserts/washers
Discussion in 'Traditional Hot Rods' started by Custom Riviera, Mar 2, 2019.
  1. Custom Riviera
    Custom Riviera
    Is anyone familiar with any special inserts or washers that fit over the studs and under the lock washer andbolts when installing Evans heads?
  2. FritzJr
    FritzJr
    You should always use hardened steel washers under the nuts on aluminum heads on a flathead. Most all of the early Ford vendors will have them. There are no special requirements for Evans heads.
  3. tubman
    tubman
  4. RichFox
    RichFox
    I found good hardened washers from ARP were best. Many hardened washers are case hardened. Hard for .010 or .015 on the surface. Soft underneath. Good for most things. But on an aluminum head they will cup and cause the aluminum to do the same. Get a good tool steel washer hardened clear through and that wil not happen
  5. deathrowdave
    deathrowdave
    from NKy
    I had to make some for a Buddy , could not find any of the correct size . I made them from bar stock one at a time . No issue to date and that was 8 years ago .
  6. Beanscoot
    Beanscoot
    I don't think lock washers as mentioned in the original post are a good idea.
    Hnstray likes this.
  7. deathrowdave
    deathrowdave
    from NKy
    No lock washers !
  8. oj
    oj
    ARP has a washer that steps down into the hole to keep the aluminum from collapsing into itself.
    I can't post a pic of them for some reason, they are made for aluminum cyl. heads and called 'step washers' or 'Insert washer' - google 'ARP 200-8550', I use them from 1/4 on thru 1/2"
    Hnstray and blowby like this.
  9. blowby
    blowby
    from Nicasio Ca
    Wow, good to know. Fist time putting aluminum heads on my 60hp with 3/8" studs I used hardware store washers. When that didn't pan out I got hardened washers that are doing fine but next time I will use these. Thanks!
  10. oj
    oj
    A V8-60? Post up some pics of it, I think those motors are the coolest thing! I have one and keep thinking about getting it dressed up like 3/4midget motor as a stationary display.
  11. milwscruffy
    milwscruffy
  12. blowby
    blowby
    from Nicasio Ca
    It's no beauty queen but gets driven a lot.
    dwollam, oj and RichFox like this.
  13. oj
    oj
    AwJeez, I that don't look right at all, I must've wrote the number down wrong. I pulled a pack from my bench for 3/8ths, try ARP# 200-8572. That 2pack looks like regular headbolt washers, not the 'Insert Washer. Sorry about that.
    I can't find an angle image so you can see the 'step' that goes down into the bolt/stud hole.
  14. Custom Riviera
    Custom Riviera
    Thank you to all responders!!!
    I learned a lot and will follow up with the ARP hardened chamfer washers.
