Technical Evans intake missing holes?
Discussion in 'The Hokey Ass Message Board' started by oliver westlund, Apr 11, 2023.
  1. oliver westlund
    oliver westlund
    Anyone ever seen this? Noticed tonight that on my evans intake they eliminated some of the mounting holes...youd think this might cause sealing issues, right? 20230410_181510.jpg Thought it was interesting!
    Deuces and scotts52 like this.
  2. Budget36
    Budget36
    Just a thought, looks like more m*** where the bolts are missing. Being that it bolts down flat, I’d liken it to a (gasp) LS based engine with 6 bolts holding the intake down.
    That said my intake gaskets “let go” but I had around 180k on the engine at the time.
    I’d bet you’ll be fine.
    oliver westlund likes this.
  3. 55 Ford Gasser
    55 Ford Gasser
    Check your block. You might find that it is not even drilled for all the holes that the Fenton manifold has. When I built my flathead ('50 Ford) I drilled and tapped holes in the block to match the extra holes in the Edlebrock intake.
  4. BJR
    BJR
    Flip them both over and take a picture of the back side.
  5. My Flathead Edmunds Racing manifold has a few holes missing too. Seen the same on other manifolds as well.
  6. tubman
    tubman
    Yep. If your 8BA block has the extra holes, you can bet they are not from the factory. I imagine that the powers that be at Ford decided to save a little on every block. It ads up over time. That being said, I've never had a vacuum leak on a properly ***embled engine, even with the manifolds with extra holes.
    oliver westlund and sidevalve8ba like this.
  7. ekimneirbo
    ekimneirbo
    from Brooks Ky
    It appears that the intake runners were joined instead of kept individual which may provide a better path to the engine. Those single p***ages look pretty small.
  8. tubman
    tubman
    As a point of interest I have a Sharp 4BBL manifold for an 8BA. Surprisingly, it has two holes in the manifold that have no corresponding holes in the block, and one tapped hole in the block with no corresponding hole in the manifold (or vice-versa). Because of this, the only thing I have used it for was my "Quadra Jet to Flathead" experiment (which did not end well). I suspect it was a large manifold vacuum leak, but never got it running well enough to fully check that out.
  9. oliver westlund
    oliver westlund
    Very interesting!
  10. BJR
    BJR
    So..... obviously someone is hoarding intake manifold holes.:eek: Who is it, come on fess up! :D
  11. tubman
    tubman
    I admit it; I have all of them. Unfortunately, I can't find them.:(
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Deuces and Budget36 like this.
  13. Bandit Billy
    Bandit Billy
    ^^^^This. My 8BA did not have as many holes as my Navarro intake. To keep it looking good I cut off a couple bolts and glued them to the manifold so there wouldn't be empty holes.
    Fortunateson likes this.
  14. That looks like a fairly stiff piece of aluminum so I wouldn't hesitate to try it.
    But I'll also refer you to the book by Leak Erickson, "How to Stuff a Gasket".
  15. seb fontana
    seb fontana
    from ct
    I thought 59AB and 8BA manifolds would inter change but you have to select/omit/add the few studs that didn't match.:cool:
  16. quickchangeV8
    quickchangeV8
    The Evans intake has worked quite well for the past 70 years. Should work just as well in 2023.
  17. dwollam
    dwollam
    No worries Oliver. Bolt 'em on.
    Dave
  18. Fortunateson
    Fortunateson
    EXCELLENT retort to a very funny comment! I love the humour of this place...!
    BJR likes this.
