Evapo Rust (it really works)
Discussion in 'The Hokey Ass Message Board' started by low springs, Jan 4, 2007.
  1. dodgedartgt
    dodgedartgt
    from SW FL
    Hey Goozgaz,
    How do you use the Bar Keep product for rust removal? Just mix it with water and dunk parts?
    Thnx, Mike Bynum
  2. abe lugo
    abe lugo
    the bar keepers friend only contains a small percentage of oxalic acid, you shoould find a store like rockler or a woodworkers store and they'll sell you a 1-2lb bag of pure oxalic acid crystals for 8 bucks. you supposed to do like a 1 gallon to about 2 oz mix. your supposed to dissolve the crystals in warm to hot water, make sure your not standing over the water when pouring in the crystals.
  3. rtc1930
    rtc1930
    are there any concerns about clean up before paint? Im not sure what you guys use to prep for paint but i always get scared i wont be able to wash off any chemicals i put on the sheet metal. l've seen guys pressure wash cars prior to paint but i have no trim, door seals, and have exposed wood im concerned about getting water in all kinds of crevises and making it worse. So any cleaning i think should be done by hand.
  4. George G
    George G
  5. Hooligan63
    Hooligan63
    Good to know this stuff works,because I just ordered the 5 gallon pre-mixed bucket a couple of days ago. Going to see how it works to free up some pistons that have minor rust on the cylinder walls.
  6. Johnny Hambone
    Johnny Hambone
    Going out right now to buy a 5er and a kiddie pool
    (56 cadillac hood)
    Where in the hell do you find a kiddie pool when its 26 outside?
  7. low-n-slo54
    low-n-slo54
    dude named craig. he has some list with odds and ends on it.
  8. LSGUN
    LSGUN
    from TX
    I've soaked some backing plates in this stuff, it's great!
  9. low springs
    low springs
    from Long Beach
    wow.... this was an old topic. i'm glad that it's worked out for all of you out there.
  10. Huckster59
    Huckster59
    looks good to me ,whats it go for $
  11. bathcollector
    bathcollector
    I bought a 20 litre of Evapo rust and dunked some pedalcar rims in it, they were a bit pitted but took a month of soaking to get clean. I have had a springer rear leg that,s been cut through the legs soaking for 3 months and still has crusty **** in the legs. Did i get a bad batch ??
  12. 1939Dodge
    1939Dodge
    Curious to see results side by side of the same parts dunked in oxalic acid and Evapo Rust.
    Sounds like Evapo Rust can take a while, also I want to make sure that either method I go with does not eat the metal...
  13. mike hamel
    mike hamel
    2 thumbs up for Evapo Rust. I use it on all of my wheels they get very rusty and the Evapo Rust is so careful it takes the rust right off the original paint and leaves you with one sweet original painted rust free rim. I love the stuff. Buy the 5 gallon drum that you have to add the water too. Believe me, its the best bang for the buck and you get soo much more out of it. I have been using my 5 gallons for almost a year. Just add water and it revives the rust remover!
  14. 66galwag
    66galwag
    from SoCal
    Would the Evaporust or oxalic acid work if you just brushed it to the surface you wanted to derust? I need to do something about the heavy surface rust on my '60 El Camino roof and it's a bit big to dunk in a tub!
  15. VinnieCap
    VinnieCap
    They say Evaporust does not clean away dirt or grime, but clears the rust. So the part actually needs to be cleaned first. That's what I was told when I called the company.
    Anyone who used it agree with that?
  16. Jim Sideways
    Jim Sideways
    from Ohio
    Looks like I will be buying alot of that, thanks for posting this!!!
  17. greazhonkey
    greazhonkey
    Yes sir, your pictures convinced me to give it a shot. I did the same and strained the product back into the jug for future use. Good stuff for sure
  18. greazhonkey
    greazhonkey
    It may not clean the dirt and grime, but it will soften it up for easy removal
  19. Hooligan63
    Hooligan63
    Actually,there's Evapo Rust,and they also have a rust inhibitor,two different products,same company. If you read the posts on this thread,I doubt it clears the rust,it removes the rust.
  20. rustyhood
    rustyhood
  21. Hooligan63
    Hooligan63
    Okay,I want to revive this thread again,because I want to know if anyone has used it in a stuck engine and what effects it had on the rings and pistons. Just wondering,because that's what I plan to use my big 'ol bucket on
  22. Hooligan63
    Hooligan63
  23. 46 rat
    46 rat
    from clever mo
    I have learned to not use it on anything that has a spring If you leave it in it to long it will take the spring out. I used it on glovebox springs and other things and it took the spring out of them.
  24. rustyhood
    rustyhood
    All I can say is I didn't know this stuff existed until I read this post awhile back and repied. Today I got a gallon and it will be in my garage for now on!
    Before I applied it [​IMG] possibly 3 hours later[​IMG]
    My old Vac wiper motors I removed are on the floor[​IMG] A couple of hours later [​IMG] Thats them on the left of photo. All of this was today. Amazing stuff for sure. Its going to make a few things easier for me for sure! And Thanks for the info!! :D
  25. McGuireV10
    McGuireV10
    from Jax,FL
    I'm re-re-reviving this thread. I decided to try the citric acid powder route.
    Will this have any negative effects on chrome, or (hopefully) any positive effects on oxidization on chrome? (I figure rust is just iron oxidization, so...)
    I have some old chrome bits I'm going to try but I probably won't have time for at least a week...
  26. Hooligan63
    Hooligan63
    I'm using the Evapo-Rust on a couple of engine cylinders that had rust scale from sitting even though the motor was a 0 mile rebuild. I'll let you know how it goes.
  27. I've seen a trick to keeping paint or rust remover, wet on a panel for a longer period of time. Simply place a paper towel, flat on the surface you're working on. And brush on your product. The towel holds more, just add more as you go along. Prevents a lot of waste, also! I just used vinegar for the first time, it's slow but sure!
  28. Hooligan63
    Hooligan63
    Well,I'll tell you something right now,I'm glad I spent the money to get this stuff! It removed the rust scale without damaging the pistons,rings or cylinder walls. Hell,I accidentally got some splash back in my eyes from the bucket and it didn't burn me or anything,but I still made a beeline to the sink to flush my eyes.
  29. rdemilt
    rdemilt
    from so florida
    So. Ive been watching the thread for a short time and read that the active ingredient in Evapo Rust could be citric acid. This got me thinking about the active ingrediant in the chemical that cleans the resins in a water softner. I went to the local softner supply house to ask a few questions and was told my thoughts were correct (citric acid). I went back home and mixed up a few s**** fulls in a quart of warm water and dropped some old parts in. Looked what happened in just 24 hours. The carriage bolt was dropped in 1/2 way as was the parking brake arm, the clean adjuster looked as bad as the rusty one before soaking and the carburator stud was old and rusty too. This can be purchased at my local grocery store (Publix) under the product name Tan X, sold next to the softner salt bags.
  30. Just one MORE reason to go with Mrs. Yankee to the grocery store!
    Did you have to rinse the parts in any special way when you took them out?
