History Evaporusting the holy part of my tank
Discussion in 'The Hokey Ass Message Board' started by topher5150, May 5, 2024.
  1. topher5150
    topher5150
    Is there an easy way to block off the sender unit hole on my gas tank so I can flip her over and soak the other side
  2. RMR&C
    RMR&C
    from NW Montana
    How does the sender attach? Make a "blank" and attach it using the gasket?????
    Hard to answer with no pic or info....
  3. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Try any old piece of tin, maybe an old can ( gal? ).
    Use a nail on wood to punch matching screw holes.
    Then an old inner tube to act as a gasket.
    Arts and Crafts
    clem and topher5150 like this.
  4. goldmountain
    goldmountain
    Cut out a plug the same size as the sending unit and put it in with the appropriate "O" ring or gasket. On the ones with a locating slot, I cut out a wedge shaped thick cork gasket and fill the slot.
    topher5150 likes this.
  5. inthweedz
    inthweedz
    If there's a small amount of gas in it, tilt one corner down so you can get a smallish dia hose in to the puddle through the gauge hole, syphon out the remaining gas and plug the hole with a rag, then flip it over..
