Ever seen a bender like this?
Discussion in 'The Hokey Ass Message Board' started by BAILEIGH INC, Aug 5, 2009.
  1. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
  2. flamedabone
    flamedabone
    Now that is intresting....Kinda looks like the same principal as pushing meat through a grinder.
    Are you guys gonna make one?
    -Abone.
  3. scootermcrad
    scootermcrad
    NEAT! Now if only it could make other shapes too...
  4. onlychevrolets
    onlychevrolets
    Scooter...thats kinna creepy that you had that playdoh image that close at hand. Is there anything you want to share?
  5. scootermcrad
    scootermcrad
    Actually, it came right up when I did a google image search. :D It's just a desperate attempt at avoiding all responsibility today.
  6. Ghost28
    Ghost28
    Man I sure could use that to make the hoop for my steering wheel right now. How about making it for me. I'd really be your friend. And I don't think the playdoh unit will work...John
  7. onlychevrolets
    onlychevrolets
    I just finished up crawling around under a church bus for three hours... Wish I could have avoided that... I'm with you ....:mad:
  8. garagerods
    garagerods
    from Omaha
    'ya know...I was sitt'n on the toilet the other day and....
  9. tdoty
    tdoty
    Very interesting machine!
    Tim D.
  10. I'm suddenly in the mood for some cheese curls...
  11. ELpolacko
    ELpolacko
    I see some serious advantages for hydraulic tubing, structural not so much.
  12. 4tl8ford
    4tl8ford
    from Erie, Pa
    Thank you for posting the Vid - My head was starting to crack from trying to imagineer how it worked.
  13. fab32
    fab32
    I'm with ElPolacko on this. After spending many years manufacturing roll cage components I don't understand how it would be repeatable for m*** produced, identical pieces. It would be interesting to see it demonstrated in person.
    Frank
  14. djmartins
    djmartins
    It is CNC so repeatability is a matter of running the same program again.
    I'd love to see a homebrewed version of this, I wonder if the CNCZone boys
    have seen this.......
    regards,
    DJ
  15. ELpolacko
    ELpolacko
    I understand how this works and how precision this method can be, maybe a bit more than standard pressure die and mandrel system. Certainly faster as there is no need for a positioner or to to reset your shoes for the next bend.
    I just question the capacity of this. That looks to be 3/4 or 1" tube in the demo video. To get anything bigger the pressures involve to do the offset die like that have got to skyrocket.
    Still very cool tech.
  16. rcoffey
    rcoffey
    :cool:You are more than welcome to come over to my place and put on a demonstration I have several projects in various stages that you could really show off its capabilities!
  17. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Ha Ha :rolleyes:
  18. Brickster
    Brickster
    I think I love tools as much as I like cars. It reminds me of a "rage against the machine" song lyric
    "**** the G ride, I want the machines that are making them"
  19. K13
    K13
    If you google it it says they make three models that can handle tube diameters from 3/4" to 2 3/8" doesn't really say anywhere what wall thickness though.
    Cool none the less
  20. temper_mental
    temper_mental
    from Texas
    That thing looks very expensive. But way cool.
  21. That thing would save me tons of time when I need to make custom headders. Can you imagine the crazy designs you could do with out having to say "how in the F#$%K am I going to weld the inside curve"
    It goes on my list of **** to buy when I hit the lotto. Till then cut, turn, weld, grind smooth, repeat.
  22. Kail
    Kail
    from Austin, TX
    I.. I think I'm in love
  23. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
  24. budd
    budd
    be interesting to see what the tooling looks like, it will probably be in Chicago this fall at fab tech.
  25. movin/on
    movin/on
    LEWD\
    but makes my manual bender look like childs play.
    MightyManx 180degree Headers don't seem so complex anymore??????
    Thanks for the link..... The wonders of computerization,
  26. RAY With
    RAY With
    Thats would have been nice a few years ago when I was hard at work. Retired now and have no need at all but what a cool deal.
  27. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    I bet it's untouchable
  28. A very neat machine, however, I question the repeatability when moving from one batch of tubes to the next. A number of years ago I designed and built an automated machine for rolling catalytic converter housings. After set-up, it would work perfectly through whatever batch of steel blanks it was forming. As soon as I got a new batch of blanks, with slightly different tensile strength charactaristics, the machine would begin to roll shells out of spec., untill reset. I worked very closely with the steel supplier who provided the blanks, and found it was virtually impossible to get exactly the same tensile charactaristics from one batch of steel to the next. I imagine tube products have that same issue.---Brian
  29. stealthcruiser
    stealthcruiser
    Oh no!!!!!, You ain't gettin' out THAT easy!!!
    I got faith in ya"!!!!!!!!!!!!
  30. hugh m
    hugh m
    from ct.
    Some pretty creative thought went into that machine. Wonder what else they (or he) have come up with? (I am still bump bending for those weird shapes.) This process may actually be similar to bumping if broken down?
