Ever think 'o jus getting another crank?
Discussion in 'The Hokey Ass Message Board' started by 440roadrunner, May 10, 2009.
  1. 440roadrunner
    440roadrunner
    from live?
  2. Michael_e
    Michael_e
    That's just too much. Wonder what it would do at Bonneville and in what cl***?
  3. zzford
    zzford
    He sure does talk funny.
  4. stuart in mn
    stuart in mn
    Sounds like a John Deere.
  5. Dempsey
    Dempsey
    from Murray, KY
    That would be fun on a golf cart
  6. RichFox
    RichFox
    I have an old R&C that has two Ts cut up and welded togeather to make a six cylinder T. At the time of the magazine (1957?) it had been running for some years.
  7. Chally
    Chally
    I was going to ask "WHY" but then again I sat there the whole 4 minutes to watch the video...
  8. stlrider
    stlrider
    Sounds like more work than just replacing a crank. WOW!
  9. Chally
    Chally
    I believe he said the crank broke and made a mess of the back end of the block...
    He also said that he got another crank to get the rear off it???
  10. I've seen this before up here in lake country, where fishermen used 1/2 of a T engine as a motor for their fishing boats. Two cylinders had more than enough power and the gas consumption was a lot less. Once I bought a T engine out of a boat for parts that was cut down to two, but still had the pan rails mounted on a frame, along with the rear bearing holding the crank. They cut down the oil pan to suit the front half, but the two unused crank throws were right out in the open, spinning away. Looked pretty dangerous, but it worked. Necessity is the mother of butchery....
  11. lippy
    lippy
    from Ks
    I have seen Model T's running two cyls and the other two as a compressor. :D
  12. Cool project.
    Did y'all note the frame is suspended on a transverse spring at the front?
    Always cool to see a project, no matter what it is, brought to completion.
    So tell me, what's a VK?
