ever use the corigated flexable radiator hose
Discussion in 'The Hokey Ass Message Board' started by harley rider, Mar 11, 2012.
  1. harley rider
    harley rider
    anyone ever use this type of hose .I have heard not to because it causes turbulance and cavitation. what do ya think?
  2. tfeverfred
    tfeverfred
    Worked good, looked like ****.
  3. squirrel
    do you mean the old "universal" black rubber flex hose, or the modern metal stuff?
    I've used the old ones, they're neat, kinda remind me of my childhood...
    The new ones are lame
  4. tjmercury
    tjmercury
  5. tjmercury
    tjmercury
    oops premature click of the mouse! I meant I agree that they have always worked well for me but they look like ****!
  6. Never had a problem with it other than it doesn't win you any points at the NSRA Nats.
  7. 55chevr
    55chevr
    55 Chevy overheated in traffic ... I changed out the corrugated radiator hoses for fitted hoses and it didnt overheat any more ... there is something to it ...
  8. harley rider
    harley rider
    I'll agree with that.
  9. dana barlow
    dana barlow
    from Miami Fla.
    Not talking about chrome stuff,only "universal" black rubber flex hose. There are very dif types,(A)the one with no spring molded into the hose,but a spring just laying inside vs (B)the one with spring molded in as part of the hose.
    (B)The one that has molded in spring works very good,but only if the guy placing it on is not a fool. Some fool can bend to much and make it fold.
    (A)is fairly EZ to get a kink in,plus it can let the spring bunch up and not hold hose open/happens mostly when it gets hot and used on bottom hose.
    As for looks,I like them a lot if there the good one and done right looks like cooling fins to me on the hose.
    This also a place you get what you pay fore in some cases,look at how many layers of reinforcing of string are in the hose.
  10. Chucky
    Chucky
    Just a quick note about the metal flex hoses. I had one, and it ****ed.
  11. Dane
    Dane
    from Soquel, CA
    These work great and aren't going to split or collapse. I use stainless t-bolt clamps instead of the cheapos.
  12. squirrel
    yup! and here's the ugly way
  13. 1Bad67
    1Bad67
    Like an ugly chick. Still works, just not so well. And you don't want your friends to see you with one.
  14. squirrel
    heh....got my engine in Hot Rod mag a couple months ago with that ****....
  15. cheepsk8
    cheepsk8
    from west ky
    Yeah, I use one. Works great and pisses off the restorers every time I raise my hood.
  16. fleetside66
    fleetside66
    Geez, I never realized there was such a negative stigma attached to these things. How the hell can I cover mine up with no hood? Actually, only my lower one is of that ilk, because of a ridiculous tight turn. The upper is pre-formed, found on the ground in a junk yard. No overheating problems, though, thank you very much.
  17. falcongeorge
    falcongeorge
    from BC
    I dont see any pre-formed hoses when I look in the magazines from the fifties. I know that stuff doesnt matter on the HAMB, but just sayin'...
  18. squirrel
    Used to be every gas station had a nice ***ortment of the flex hoses, and no molded hoses. Remember that?
  19. scrap metal 48
    scrap metal 48
    I got a bunch hanging on my garage wall next to many fan belts......
  20. brigrat
    brigrat
    from Wa.St.
    I find these to be to rigid even with the rubber coupling, some radiator outlets will not take the vibration................
  21. 5window
    5window
    Mine's set up like Dane's. Had an impossibly short, double turn and down hose position for the lower hose. The old one was a section of something I spent hours staring at hoses trying to match. Bought some Cool-flex and fitted it in 10 minutes.
    You don't have to like it, it's my car.
  22. falcongeorge
    falcongeorge
    from BC
    Like it was yesterday. Back in the days when gas stations sold gas and car parts, instead of gas and potato chips...:rolleyes:
  23. falcongeorge
    falcongeorge
    from BC
    The irony is, you see flex hoses all the time in TRJ, but the HAMB, bastion of "traditional" hot rodding looks down their nose at them. Good enough for Ganahl, good enough for Brizio when he restored the Ala Kart but not for the the HAMB. "Period" hot rods with smoothed firewalls, no voltage regulators, and molded hoses...:rolleyes:
  24. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Period correct :)
    Not correct, Period!!!! :rolleyes:
  25. falcongeorge
    falcongeorge
    from BC
    Good one!:D
  26. patrod
    patrod
    from idaho
    A friend had a molded lower hose that would **** down on his big block camaro,he put a flex hose
    with the spring in it, overheating problem solved!
  27. milwscruffy
    milwscruffy
    It was probably missing the spring that was suppose to be inside it.
  28. 49ratfink
    49ratfink
    I hate flex hose. bought a car with flex hose, thought I going to keep it so I went out and found proper fitted hoses to fit the car. I ended up selling it and saw it later on ebay with a rubber flex hose along with a cheap paper element replacing the K&N that was on there. Must have taken it to a "mechanic" for a safety check or some such nonsense.
    I just think it looks ugly. I bet it works just fine.
  29. [​IMG]
    If they were good enough then , they are good enough now!!!!
  30. pasadenahotrod
    pasadenahotrod
    from Texas
    It is so easy to pick up a moulded hose for most applications in hot rods and looks so much cleaner and more hotrod-like.
    I have always believed that it just showed that little extra bit of pride in fitment and appearance.
    No real functional difference but the flex hoses in some applications can cause problems with cracking radiator necks loose from tanks.
