ever use the corigated flexable radiator hose
Discussion in 'The Hokey Ass Message Board' started by harley rider, Mar 11, 2012.
  1. Johnny Gee
    Johnny Gee
    from Downey, Ca
    At least the engine won't stall with that set up ;)
  2. tfeverfred
    tfeverfred
    And isn't that one of the things we strive for? The molded ones look like you tried a little harder to get things right. Especially when you're running hoodless.
    Factory valve covers work great, but they get swapped out quick.
  3. squirrel
    yeah...still running stockers in the car of mine that has the flex hose.
    If you want the car to look like an old hot rod, then the rubber corrugated hose is the way to go. If you want it to look really nice, then the molded stuff is neat...or bend up some metal tube, and use short straight rubber hoses to connect it.
    Whatever you want, it'll work.
  4. falcongeorge
    falcongeorge
    from BC
    I think Metalshaper kind of wants to distance himself from that, but it looks like this is gonna take on a life of its own. Embrace your destiny Metalshaper, embrace your destiny...:D
  5. I'm going to use whatever hoses I can get to fit ....I don't care what kind they are.
  6. OoltewahSpeedShop
    OoltewahSpeedShop
    My roaster has had it on the lower hose for 50+ years.
      159.5 KB
  7. 48 Poncho
    48 Poncho
    from Tennessee
    I use the ugly one and no problems so far. Doesn't bother me right now cause everything else looks like **** under the hood too (for now).
    48 Poncho
  8. tommyd
    tommyd
    from South Indy
    So have rear spring shackle exstensions but........ugh!
  9. Paul
    Paul
    Editor
    factory valve covers and flex hose works for me.
  10. johnybsic
    johnybsic
    from las vegas
    I dunno... I acutally like the way they look.
    I remember seein um on hot rods growing up...Even if im only 24.:rolleyes:
    That and finding a molded hose CAN be a pain in the ***, even then seems like the one i find that i can cut to fit is always like $40 fu*kin dollars :eek:
    Godddamnn im gonna cut it up!.
    thats a set of plugs and a gallon of 91*
    I wouldn't hesitate to use um, I focus on $$$:Go fast ratio.
  11. tommyd
    tommyd
    from South Indy
    Daaaang! They look better on the 57 than they did on my 65 Mustang! I don't have a problem with the ruber molded hose. It's the metal ones that scream "Pro/street or Streetrod" Them....not so much!
  12. What the hell do u give a s**t what other people think. I run em and work/look great TO ME.:)
  13. The37Kid
    The37Kid
    I'll need two with 1 1/2 ID for "Alley Oop'.
  14. Mopar Jack
    Mopar Jack
    Ive had the shiny metal one on my 32 for over 10 years with no problem...
  15. Racer29
    Racer29
    I use the flex hose too and have had no problems. It's not like someone digs your hotrod until they see the flex radiator hoses and then they're completly disgusted with it. In the 10 years I have been driving my Sedan there has not been a single comment on the radiator hoses, carb scoop yes, flex hose no.
  16. gwhite
    gwhite
    SUPER MODERATOR
    Posted this on another thread as the subject came up...they've been around since the early 40's;
    And a photo of the Vesco & Denkins streamliner at El Mirage in '49 (note the flexible radiator hose at the far right of the photo).
  17. bustingear
    bustingear
    Those ribbed flex hoses are a mark of nostalgia to me. I could have used the plain ones and sought out these with a purpose on my 28 sedan highboy. They are also greater pleasure for her but they fall short on the receptacle ends.
  18. gimpyshotrods
    gimpyshotrods
    Have them on my rod. If that is what you notice when you look at it, then I have failed, or you're really jaded. Either way, they work fine, and I don't care.
