1952-59 Ford Evintho's '54 Customline build
Discussion in 'Off Topic Hot Rods & Customs' started by evintho, Feb 15, 2020.
  1. evintho
    evintho
    Well, the time has come. Time for a build thread on the '54. The car has been waiting in the wings for 5 years while I finished the roadster project. The roadster is done. Here's the build thread for that...…
    Projects - Evintho's '27 roadster build thread | The H.A.M.B.
    Now on to the '54!
    I'll keep it here in the social forums 'cause I'm confident the HAMB traditionalists won't be too happy with computer controlled fuel injection!
    $1800 bought it. Complete and original....
    Searching around for a drivetrain I located this '93 Mustang with a good running 5.0/AOD combo for $1500. I actually bought this 2 years ago and the wife and I have been enjoying road trips with the top down during the summers.
    First thing I did was pull the front sheet metal to see what I had to work with....
    65 years of grease, dirt and ****. The stuff was literally an inch thick! I s****ed as much off as I could but I really needed to give it a good sandblasting just so I could see some of the suspension bolts! I built some blast barriers out of s**** lumber and clear plastic sheeting...…
    I gave it a cursory blast, yanked the motor and ****** then rolled it into the garage...…
    I decided the first problem that needed addressing were the rotted toeboards, floorboards and rocker panels...….
    I priced out some EMS repros for all the pieces I needed and it came out around $1500! Not gonna happen! I can build my own. Picked up some 18ga remnants at the local steel supply house for $80 which was more than enough to handle my needs! Opened up the drivers side first and found the body brace rotted through....
    Remedied that...…
    welderdave562 and Kustomline54 like this.
  2. evintho
    evintho
    The front cowl mount was also toast.....
    Fixed that...…
    In addition, the inner rocker panel where the body brace attached was a mess.....
    Done.....
    On to the rocker panel. Opened it up and coated the inside with POR15. Cut a length of 18ga to shape and welded it in. I even cut the factory wire clip off the old rotted panel and attached that....
    Had to fab a new piece at the bottom of the door jamb also. That side done.
    Next up, toeboard. I got a little over zealous with a ball peen hammer trying to form the stiffening rib. That didn't work out so I resorted to my cheap Harbor Freight bead roller. The 1/2" die worked perfectly to form stiffening ribs!
    Then I cut the floorboard...…
    I formed the roll that transitioned into the trans tunnel with my high tech rolling tool.....
    Many beads to roll on my cheap HF bead roller and couldn't have done it without my ***istant (and wife of 34 years). This ain't her first rodeo either! She's helped me pull many a motor and trans over the years!
    All ****oned up....
    welderdave562, Rui and mikhett like this.
  3. evintho
    evintho
    On to the p*** side.
    This side was more extensive so I decided to pull the door for easier access. Built a door dolly out of 2x4s and some cheap casters I had laying around. Made it real easy to pull the door myself (didn't even need the wife to help) and it's mobile so very easy to roll around.
    Cut out the offending cancer.....
    Same rot issues with the right side body brace and inner rocker.....
    Done....
    Right side toeboard….
  4. evintho
    evintho
    Had to replace the right rear floorpan also.......
    Had to make the small 'under the seat' section outta 5-6 pieces because of the elevations....
    I think it came out pretty good considering it was all done on the cheap!
    While I was at it I noticed rust starting to come through the previous owners bodywork on the p*** side rocker panel. I ground the old bondo out and found this mess....
    Cleaned, derusted, POR15'd and welded in a new panel. A fresh coat of mud should get it looking just fine.
    Next up is lay down some seam sealer and primer then I'll probably jump on the front suspension. More to come!
  5. JeffB2
    JeffB2
    from Phoenix,AZ
    Great work on the panels and rust repair,how is the front cross member ? There is blueprint for that in the "Sticky Faq"
    mikhett likes this.
  6. mikhett
    mikhett
    from jackson nj
    Good Wife ,Good life! We have been married 50 years! Good luck!
  7. okiedokie
    okiedokie
    from Ok
    Good work, looking forward to more.
    mikhett likes this.
  8. 56longroof
    56longroof
    Awesome work!
    mikhett likes this.
  9. evintho
    evintho
    I clicked on that link and got 'HAMB Error'. In fact I clicked on a bunch of those links and got the same message. Unfortunate because I was kinda relying on a lot of the info in the stickys. Examples: Adaption of a dual master cyl and power brake booster utilizing 4-wheel drum brakes (I'm not converting to discs) and conversion to self adjusting drum brakes. I got 'HAMB Errors' on both. Is there any remedy or info on those subjects?
  10. JeffB2
    JeffB2
    from Phoenix,AZ
    bondojunkie and danman55 like this.
  11. JeffB2
    JeffB2
    from Phoenix,AZ
    This link may help some: https://www.jalopyjournal.com/forum/threads/tonight-i-am-not-happy.1103171/#post-12515347 see the video. This video shows the installation of the self adjusters On a 52-54 you may have to re-position the adjuster slot guys have done that with a Dremel cut off disc,here are the part numbers from Autozone for the self adjuster kits. Front kits you need 2,#2514, rear kits #2515 also need 2, you will need 2 All in one kits part # H7045
  12. JeffB2
    JeffB2
    from Phoenix,AZ
    Check your "Conversations" in box for a message.
  13. Kustomline54
    Kustomline54
    Right on! Congrats on the buy! I'm in the middle of doing floor work on my 54, so I'm in awe of your pics haha. Looking forward to the progress of your car!
  14. okiedokie
    okiedokie
    from Ok
    I had to reposition adjuster slot on one side of my 55.
  15. evintho
    evintho
    Got a couple more things done. Prepped and primed the floorpan and layed down some seam sealer.
    Didn't want to pay $30 a tube for the high end automotive stuff so I picked this up at Home Depot for $7 a tube. I used a case of this when I painted my house last year and it's quality sealer. Good enough for my house, good enough for the car!
    Done with the floors!
    Moved onto the next task, pulling the front suspension which will be rebuilt.
    With no front end I needed a way to roll it out of the garage when I pull it out for sandblasting so I built a car dolly using 1" square tubing and some casters I had. Rolls quite nicely!
    bondojunkie, danman55, JeffB2 and 8 others like this.
  16. 50Poopbox
    50Poopbox
    Floors look good. Hopefully my $700 invested in EMS turn out as nice. Probably more patches needed as well but that’s what I can tell before I start cutting them out. I might have to get one of those HF bead rollers for my trunk pans.
    Are you going back to stock suspension or bags?
    danman55 likes this.
  17. Pheaton193
    Pheaton193
    from Reno, NV
    Nice work!
    danman55 and JeffB2 like this.
  18. evintho
    evintho
    Rebuilt stock suspension w/Aerostar coils. About done with the electric power steering install. I'll post some pics soon.
    guthriesmith and JeffB2 like this.
  19. Navyford
    Navyford
    Looks fantastic! I can’t wait to have this kind of skill
    JeffB2 and Kustomline54 like this.
  20. Texas57
    Texas57
    Very nice! Floors look great, as does the dolly.
    JeffB2 likes this.
  21. guthriesmith
    guthriesmith
    Floors look great! I debated the same thing on some floors (and rocker panels) I am currently working on for a OT project at least for this group. However, all said and done, I ended up only having to spend about $250 on all the patch panels we needed so went that route. A few of the parts were fairly complicated, so I didn't figure I was anywhere skilled enough to make them myself. I will have to make a few small patches out of a piece of sheetmetal I have, but nothing like you have done.
  22. bobss396
    bobss396
    Really nice so far.
  23. jailbar joe
    jailbar joe
    jobs that cost a fortune don't look any better than that......well done
    bondojunkie and guthriesmith like this.
  24. evintho
    evintho
    Just updating this build thread and keeping it current with the electric power steering install post.
    Here's the link...….
    Saturn Vue electric power steering conversion
    Before I threw the dash back in I mounted up my Newport 12v electric wiper motor. New wiper bushings too.
    I also blasted and got some paint on the front suspension pieces. I purchased new Aerostar coils from RockAuto and a new front end rebuild kit from these guys...…
    Front suspension rebuild kit
    Got all the bushings installed, now I'm just waiting for the weather to clear so I can roll the car outside and blast/paint the undercarriage.
  25. Kustomline54
    Kustomline54
    How do you like their front rebuild kit? Shopping around myself, seen they have a listing on ebay as well but debating on pulling the trigger with these guys
  26. bobss396
    bobss396
    Three guesses on where they are made, but they seem to strive to make good stuff.
  27. danman55
    danman55
    this is a great thread - subscribed, "watched" or what have you. Keep it coming!
  28. evintho
    evintho
    Well, it's the cheapest one I've found, fast shipping and great communication. I went over each piece pretty carefully when it arrived. Seems to be fairly decent quality! Rubber dust boots seem thick, castle nuts are large (I've seen Speedway nuts that were half the size), each piece is individually bagged and all threads are the proper ones and good. As far as I can tell the rubber bushings look good. Maybe the steel isn't of the highest quality but, they don't make steel today like they did in '54! Here's a pic comparing the bushing shell collars. They're the same thickness.
    All in all, I'm quite pleased....and I luv the price!
    Texas57, Kustomline54 and JeffB2 like this.
  29. Kustomline54
    Kustomline54
    Awesome to hear, definitely helped with my decision thanks! Great thread!
  30. evintho
    evintho
    Glad it helped you!
    Continuing on......today was a dirty day! Started out by removing all the factory seam sealer that Ford installed in the rear trunk area behind the bumper. It trapped a ton of moisture and the panels just rotted through. The PO decided to bondo over the rust! Out of sight, out of mind!
    After recovering from my bout of depression, I turned my attention to s****ping out the seam sealer in the drip rails.
    This just keeps getting better and better!
    Also, stripped off the door weatherstripping. Looks like the metal work isn't going to end anytime soon!
    Finally finished off the day with a bit of satisfaction. Was able to clean up the nasty factory gas/temp gauge cluster. Came out pretty good.
    That's all for today.
    ffr1222k, bondojunkie, Rui and 2 others like this.
