Technical Excelsior tires
Discussion in 'Traditional Hot Rods' started by koolbeans, Mar 7, 2021.
  1. koolbeans
    koolbeans
    Do they sing/wine goin diwn hiway?
    Mine do at 40+.
    They are radials.
    Sent from my XT1710-02 using The H.A.M.B. mobile app
  2. They sing because they're happy, they sing because they're free......
  3. alchemy
    alchemy
    You should remove the mufflers.
  4. Aaron D.
    Aaron D.
    I don't notice mine singing.
    stillrunners likes this.
  5. pprather
    pprather
    I've wondered about that because the tread pattern is fairly aggressive, in my opinion.
  6. If they hum.......
    it's because they forgot the words to the song.
    All seriousness aside, I hear* that they are relatively quiet.
    *pun
  7. Bigmac48
    Bigmac48
    from Dundalk Md
    Don't have any but they sure look right on all those roadsters and opened wheeled coupes
  8. Mr48chev
    I've talked to the guy who runs this Bentley a couple of times since he put them on it and all he said is there is a world of difference in the way it drives. Bently gr (2).jpg
    The car is a beast and his friends say he wheels it at a pretty good clip down the highway.
  9. 19Eddy30
    19Eddy30
    from VA
    I ran a pair on my 32 front . Did not notice anything on usual.
  10. gearhead695456
    gearhead695456
    Mine do not, could be your axle gears or the bearings?
  11. John Stimac
    John Stimac
    alfin32 likes this.
  12. denis4x4
    denis4x4
    from Colorado
    Ran both bias and radial Excelsiors on the Zipper and never noticed any excess noise.
  13. Blue One
    Blue One
    from Alberta
    My Excelciors run fine, no excessive or unusual tire noise.
    73287FD6-A36B-4D25-86ED-DA85796E1D70.jpeg E14745FC-4202-4D7C-B854-0E9907E049E3.jpeg 008AD04E-FE05-47BE-B383-623A21312B53.jpeg
  14. xlr8
    xlr8
    from Idaho
    There are two different things that go on with tire noise. One is the whine of the tread on the pavement, and the other is from the air hitting the tread blocks, mostly on the front. If it is an issue of the airflow over the tread it will be less noticeable on more aerodynamic or full fendered cars. I'm sure most of us can remember how highboy 4WD pickups used to have that front tire whine from running bias ply traction tires on the front, and it seemed like you never noticed it with 2WD pickups sitting lower and running highway tread tires.
  15. RockyMtnWay
    RockyMtnWay
    you are not imagining things, the Excelsiors radials do sing
    Jim Bouchard, alfin32, RMR&C and 6 others like this.
  16. koolbeans
    koolbeans
    Thanks for the input. I have the same experience. Just drove 60+ miles on fresh new silkie asphalt and they did sing. Not bad for awhile but became anoying.
    Im just down the road from diamond backs. Ill check in.
    Keep me posted.
    pprather likes this.
  17. koolbeans
    koolbeans
  18. 19Eddy30
    19Eddy30
    from VA
    A subs***ute tire four Excelsiors is a Tire for Electric vehicles 16 inch Bridgestones
    Around $100
  19. Blue One
    Blue One
    from Alberta
    This is useless information without the tire model and size specifications and also a link to the online information.
    Pictures would be good too.
  20. dwollam
    dwollam
    Those were 195/80r 16 Bridgestone ecopia but I can't seem to find them anywhere now. Look interesting when I saw them some time back. Was for electric or hybrid cars around 2000.
    Dave
  21. 19Eddy30
    19Eddy30
    from VA
    I sold all 4 rims &. Tires off this one of my 32s
    Front Excelsiors
    The tires on Rear are the alternate to Excelsiors ,
    16 inch diameter 7 inch wide rim,
    Radial tire 28 inch tall side wall to side wall was around 9 inch wide
    Tire Said on side wall about inch tall
    ""FOR ELECTRIC VEHICLE ONLY""
    When I found this tire I was using Cooker tire catalog for tire specs , then going threw other manufactures tires
    Compurter !
  22. X38
    X38
    Sizes?
    Blue One likes this.
  23. RockyMtnWay
    RockyMtnWay
    Auburns; 5.50-16 front and 7.50-16 rears.
    RMR&C, X38 and Blue One like this.
  24. Blue One
    Blue One
    from Alberta
    Have to look and see if they do a 7.00 -16
    Might try them when the Excelciors wear out.
  25. X38
    X38
    Thanks. Confirms my su****ions.
  26. banjorear
    banjorear
    The do have 7.00 X 16". I just looked.
  27. Blue One
    Blue One
    from Alberta
    I looked too but I do see a problem, they don’t appear to have any 5.00x16” which is what I have on the front now with my Excelciors
