Technical Exhaust Drone/Resonance
Discussion in 'The Hokey Ass Message Board' started by lake_harley, Dec 17, 2025.
  1. lake_harley
    lake_harley
    I am wanting to quiet exhaust noise, preferably without replacing mufflers. It is what I would call a resonance, or maybe the proper term is drone. Part of the noise problem is turn-downs about 18" forward of the rearend with only about 18" of tube length behind Megaflow mufflers. I do want to extend the exit point to angle down slightly just ahead of the rear axle tubes. Just wondering, would a cross-over pipe ahead of the mufflers help to eliminate the noise level and drone at highway speeds?
    Lynn
    ydopen and chryslerfan55 like this.
  2. alchemy
    alchemy
    Move the noise to the rear of the car, and drive fast so it won’t catch you.
    Acres, RICH B, Weedburner 40 and 17 others like this.
  3. lake_harley
    lake_harley
    I'm sure it won't do 700+ MPH.:eek:
    Lynn
  4. Ebbsspeed
    Ebbsspeed
    Pretty much any exhaust that exits under the car is going to do that, especially behind "mufflers" that really don't attenuate the sound a lot. Move the exit point of the pipes out the side or rear.
  5. NoelC
    NoelC
    Somewhat, but not enough would be my guess. I'd replace the mufflers. Megaflow? Like who drives that fast to justify the noise? I'm a fan of quiet. Value my hearing maybe? But to each his own. If you keep them you might try a wrap. That header wrap should dull the drone. I did an asbestos wrap over the tail end of duals I made and secured it down with half shells and clamps and while it was more for preventing heat transfer, it also had the effect of dulling down the vibes.
    Maybe take a page from the gun crowds and add home made exhaust silencers in that last 18" ?
    The other thing to ask is what sound dampening and sound proofing is there in the car? If your doors are vibrating because the're hollow core, you might need a different fix? Well that what I got to offer.
  6. lostn51
    lostn51
    from Tennessee
    Change mufflers and run the exhaust out the back of the car. I had an OT Falcon that I ran 3” exhaust to a set of 2 chamber Flowmasters with dumps before the rear end and it was almost unbearable at times. I ran the exhaust all the way out back (still 3”) and all it did was move the rumble out back but the resonance was still unbearable.
  7. Ziggster
    Ziggster
    Never heard of this before, but reminds me of those copper pieces of pipe next to faucets used to eliminate water hammer. lol!
    alanp561, Tickety Boo and Just Gary like this.
  8. Ziggster
    Ziggster
    Interesting. I built a dual exhaust (2.5”) using a Flowmaster 10 series (2 in/2 out) with side exists on PS before rear axle for daughter’s OT pickup with a 5.7. It was super loud. NASCAR like. It’s now my DD, and was thinking of moving it to the rear. Guess not now…
    lostn51 likes this.
  9. I don’t know if you see it but when I did the exhaust on my 53 I dumped it out just in front of the rear wheels.
    It has a very healthy 261 Chevy 6 straight pipes I built the exhaust of heavy wall 2” Stainless Steel milk line.
    The loud does not bother me but it drones, which bother me on long trips.
    I plan to solve the problem by running the exhaust all the way out the back
    alanp561 likes this.
  10. lostn51
    lostn51
    from Tennessee
    This was a 12:1, solid roller, gear driven beast of a small block. It snap crackled and popped when it was running and even with a gear (4:30) it still was camming pretty hard cruising in rush hour traffic. It was fun to listen to but after a while it would give you a headache :(
    Ziggster likes this.
  11. cfmvw
    cfmvw
    An OT car I had used a Borla muffler near the end of the exhaust system. I later added a round Magnaflow muffler upstream to quiet it down and mellow the tone.
  12. garyf
    garyf
    Some Chrysler cars from the factory had a weight hung on the exhaust system to absorb resonance,sometimes a hunk of cast iron on the end of a rod.
  13. Rickybop
    Rickybop
    Exhaust exiting under the floorboards is like being inside a drum.
  14. Tickety Boo
    Tickety Boo
    from Wisconsin
    A crossover or H pipe would help, but I've been told a X pipe was better by a guy that still had a bad drone with an H pipe that got less with the X pipe.
    Tail pipes get the noise out of the p***enger area
    427 sleeper likes this.
  15. lake_harley
    lake_harley
    Thanks for the replies. The comments that the mufflers need to be changed is what I expected but sometime I need someone else to validate it. I'll get the end of the pipes as far back as practical. I would love to dump the exhaust out to the sides just behind the rear wheels but the configuration of leaf springs and a gas tank in the way would make the one pipe look like something Rube Goldberg designed.
    I've heard it said, "If it's too loud you're too old" and I guess this confirms that I'm just really old. When I was in my early twenties open headers would have been my exhaust system of choice but that's certainly no longer the case for a daily driver.
    Lynn
    BTW.... In my own defense I'll mention that I didn't install the mufflers, they were on the car when I bought it.
  16. hepme
    hepme
    Walker FX or quietflow works nicely, have had 'em on two of mine and love 'em. Can thank straights, headers, straight thru muffs, and just screwing around with loud **** on old cars --oh, and i forgot the 8 years of USAF airplanes-for my 2K hearing aids that I now need to replace because my hearing is getting worse--if that's possible!!
  17. Ebbsspeed
    Ebbsspeed
    I've always liked that look, and did exactly this on an O/T Nova with an evil, wicked, mean and nasty 350 under the hood, through what were then known as "turbo" mufflers. This was AFTER running it for about two weeks with header mufflers and short dumps underneath the car, which was so loud and annoying that I couldn't stand it. It made it a whole different car.
    lake_harley likes this.
  18. blue 49
    blue 49
    from Iowa
    My car and truck have similar engines, same pipe size and same gl*** packs. The truck has rams horn manifolds and drone. The car has fender well headers and no drone. Both have turndowns under the car, near the rear axle. The only explanation I can come up with is the car exits outside the frame rails and the truck are inside the rails.
    Gary
  19. oldiron 440
    oldiron 440
    It’s been my experience over the years that the exhaust systems that have more drone is usually in the muffler. I’ve even had a OT stock late model Dodge pu that had quite a bit of drone and it had the 4.7 v8 not the Hemi. I’ve had full duals installed on several cars and had problems with drone and what I’ve found in all but one was the hangers mater. To short without flexibility or too many hangers can cause drone, often one flexible hanger on the muffler and one the tailpipe is all you need. On only one vehicle a 69 Pontiac With a 400 I ended up with resonators on the tailpipes. But even this was done only when the original owner wanted to buy the car back but didn’t like the sound of the exhaust I had put on it. I’ve had good results with even gl*** packs bolted to the headers with 3” cores and turndowns as long as the turndowns end level with the body so the exhaust is pushed away from the body at speed. It might make the ashtray lids dance at idle but it’s reasonable at any road speed.
    Deutscher and Tickety Boo like this.
  20. jaracer
    jaracer
    I've got a pair of Porters on my Model A (401 nailhead), no drone or really loud exhaust inside the car at cruise speeds.
    warbird1 and Tow Truck Tom like this.
  21. earlymopar
    earlymopar
    I agree with both of your suggestions plus moving the mufflers as far back in the system as possible / reasonable.
  22. Doublepumper
    Doublepumper
    from OR-WA, USA
    Dual 2-1/2" Vibrant Performance Street Power stainless, headers, no crossover, plumbed out the back. Mufflers mounted forward of the hump pipes at the rear end. Nice rumble until hammered, then wicked roar...and no drone. Flowmasters sounded like **** to me. These VP's are nice.
    kabinenroller likes this.
  23. Dan Timberlake
    Dan Timberlake
    When it's droning can your finger tip feel the floor or door panels buzzing faintly?
    That can be too stiff hangers OR loud noises coming out the pipe exciting flat panels with no sticky gunk for damping/deadening.
    Is it a particular engine speed, or a wide range of engine speeds.
    There are apps for Smart phones that can ****yze sound frequencies.
    Helmholtz resonators need to be tuned to the frequency that bugs you. https://www.omnicalculator.com/physics/helmholtz-resonator
  24. 05snopro440
    05snopro440
    They don't actually work as intended for water hammer. They eventually just fill up with water.
    Beanscoot likes this.
  25. 05snopro440
    05snopro440
    You need to get the exhaust pipes to the rear and out from under the car, and you need to pick the right mufflers.
  26. Jack E/NJ
    Jack E/NJ
    from NJ
    I use stainless baffles similar to this. Insert & secure in end of each tailpipe.
  27. kabinenroller
    kabinenroller
    I am also running Vibrant SS mufflers ( oval shaped) 2 1/2” SS tubing with all mandrel bends. I have big tube headers, no crossover, the mufflers are located under the rear seat area just before the tubing goes over the rear end housing. I installed small Vibrant resonators just behind the mufflers, the exhaust tubing exits behind the rear wheels. Absolutely no drone or “school bus” rapping, just a deep muscle car sound. Perfect.
  28. lake_harley
    lake_harley
    ^^^^^Beautiful!!
    Lynn
    williebill and Tickety Boo like this.
  29. GARYLH
    GARYLH
    Haven't tried it, but years ago I was told by someone who did, that a stainless hose clamp around the pipes will suppress drone.
  30. Mr48chev
    Back years ago when I lived in Texas I had a buddy with a 383 Mopar that he had turbos and turn downs in front of the rear axle that rode with one time for a 40 mile jaunt from McGregor to Little River for the drags and that was the first and last time I ever rode in that car. The drone gave me a three day headache.
