Exhaust Hanger Ideas
Discussion in 'The Hokey Ass Message Board' started by scootermcrad, Nov 5, 2013.
  1. scootermcrad
    scootermcrad
    Hey guys!
    I've got some decent ideas on some simple exhaust hangers, but nothing I love. I could use some inspiration for some clean and simple, single-point mounts for those of you who are running your exhaust pipes through the frame.
    Let's see some ideas!
    Thanks guys!
    S
  2. scootermcrad
    scootermcrad
    Bttt
  3. seb fontana
    seb fontana
    from ct
    McMaster Carr..Look under vibration dampers..they come in lots of sizes, rubber hardness, studded or threaded..
  4. SCtattooer
    SCtattooer
    I knew a guy who made his exhaust hangers from the uprights of a station wagon roof rack, complete with pentastar cutouts. Neat!
  5. fordflambe
    fordflambe
    Not as cheap as making your own but Speedway has brackets and isolators that you may want to look at........
    mgtstumpy likes this.
  6. bustedwrench
    bustedwrench
    I've seen some cool hangers made from old engine connecting rods.
  7. deuce666
    deuce666
    from Oregon
    Here's a picture of how I did the front exhaust hangers on my '32. I welded a 90 degree rod to the exhaust clamp and run the other end into a rubber insulator (which I think was a Pyle MHV6). Hope this helps.
    fiftyv8 likes this.
  8. scootermcrad
    scootermcrad
    Thanks for sharing man!
    Keep 'em coming guys. Looking for ideas on stuff you have made, not necessarily stuff bought and bolted on.
    Thanks!
  9. scootermcrad
    scootermcrad
    McMaster Carr (aka, the catalog bible) does have a bunch of great isolators. Have a pile of them from other projects and will probably utilize them. That's what I was hoping to see here. Small, simple, does the trick...
  10. NortonG
    NortonG
    I used to work at a salad dressing factory and we had a bunch of the clamps like the one pictured, but in stainless steel.
    I always wanted to use them as exhaust hangers with a rubber isolator between it and the frame.
  11. 57 HEAP
    57 HEAP
    I used a set up like deuce666 did. The trick is to attach the rod to the pipe so that the center of gravity is directly under the hanger. If you come off the side like the above picture you may induce a twist in the pipe that will "shake out" once the car is driven.
  12. hey buddy,
    I have used coat hangers before. Simple as hell. :D:D
    Unless you have your engine mounted solid, I mean really solid you are going to want your exhaust hangers to float as in rubber mount. I would not run a mount out in th air where anyone can see it and then put a good rubber mount inside the frame. let it look like it is floating.
  13. LOST ANGEL
    LOST ANGEL
    Yup!
  14. scootermcrad
    scootermcrad
    Haha! Good stuff!
    Yeah, what the plan has been up to this point was to clamp something to the pipes that will interface to something bolted to the frame thru a rubber something or other. But been thinking side tabs or a single top tab for each pipe. The exhaust is pretty short from the headers back. About 48" between mounting points. Front is supported by the headers and the back by whatever I come up with.
  15. Leakie
    Leakie
    Here is a simple one that I made and then welded to the side of the exhaust pipe.
    Tim and fiftyv8 like this.
  16. pasadenahotrod
    pasadenahotrod
    from Texas
    Look under any modern car and you'll find a myriad of exhaust hanger rubbers, most of which can be bought at your local auto parts store cheap.
  17. scootermcrad
    scootermcrad
    Yeah, that's about what I was thinking right there. Thanks for sharing! Is that rubber snubber silicon?
  18. Cali4niaCruiser
    Cali4niaCruiser
    I lifted these pics from the one and only Steve Sellers. I know you're a fan as well Scott. These hangers are pure awesome.
  19. I made/ used these on my truck...
    Posted using the Full Custom H.A.M.B. App ****a!!!
  20. bp1971
    bp1971
    from Fresno, CA
    I used old piston rods, they big end fit 2" exhaust perfectly.
    fiftyv8 likes this.
  21. bobby_Socks
    bobby_Socks
    from ǑǃƕǑ
    Fastlane Rod Shop made/used these on their latest 34 Ford
    fiftyv8 likes this.
  22. Bert Kollar
    Bert Kollar
    These are great. I believe they were OEM. Available at any parts store. They allow for front to back movement as the system grows as it gets hot. Bolt to the frame and bend a 3/8 rod that welds or clamps to the pipe.
  23. Dan Timberlake
    Dan Timberlake
    Agreed those look cool. Depending on how much flexibility is provided at that pin/bolt joint I think something may crack in the next few thousand miles, if it's even a street car.
  24. Leakie
    Leakie
  25. bengeltiger
    bengeltiger
    Cactus1, those are simple and good looking! I'll have to steal them for my Falcon.
  26. scootermcrad
    scootermcrad
    Great! Now we're cookin'! Some great ideas here!
  27. 32SEDAN
    32SEDAN
    Any other creative exhaust hanger ideas out there?
  28. 41rodderz
    41rodderz
    from Oregon
    Well take some 1/4 plate , or what you want ,shape it like a banana or a swan neck eg; headlight mounts drill a bunch of holes . Put an isolater rubber in and go to town. Paint , powder coat or chrome it. Or grab some stainless and polish it until you can comb your hair in it. :)
  29. mgtstumpy
    mgtstumpy
    Nothing as exotic on my 46 Olds project, the rear frame rails have similar simple mountings. Nothing sits below lower edge of frame with everything above scrub line. I had to cut additional holes in X-nenber that I belled as per OEM for strength and aesthetics.
    My 35 Chevy, simple tabs welded to exhaust tubing and supported by large rubber bushing that attach to Jag bottom bash plate.
  30. fiftyv8
    fiftyv8
    from CO & WA
    Exhaust Pipes 004.jpg Exhaust Pipes 005.jpg Exhaust Pipes 004.jpg Exhaust Pipes 005.jpg Exhaust Pipes 005.jpg I used a homemade combination that acts as a cushioned hanger using small engine rubber mounts, I believe that Harley Davidson use similar mounts, but have not confirmed this fact.
    I like it because should the rubber fail the pipes can not drop very far.
    I use a Chevy style exhaust pipe flange which I have laser cut in several pipe hole diameters and then get the brackets cut at the same time.
    So I use Chevy gaskets and can recycle Chevy stainless exhaust pipe on old projects as flanges match.
    I get enough done to keep the price down and just keep stock and use as required.
    I've even sold and/or give sets away as sweeteners on occasions...
    32SEDAN and mgtstumpy like this.
