Hot Rods Exhaust manifold coatings
Discussion in 'The Hokey Ass Message Board' started by mikhett, May 22, 2023.
  1. mikhett
    mikhett
    from jackson nj
    What is best to coat exhaust manifolds?
  2. SS327
    SS327
    Mink, yes mink coats look very elegant on exhaust manifolds and keeps them warm too!
  3. millersgarage
    millersgarage
    I've had great success with the basic exhaust spray paints. Follow the instructions.
    Don't just spray em and install, that won't last
    hrm2k likes this.
  4. mad mikey
    mad mikey
    Eastwood coatings, hands down!
    jimmy six likes this.
  5. hrm2k
    hrm2k
    I had the headers on my old coupe Ceracoated. The same coating they use on guns.
    They looked good after 3 years
    Blues4U, mad mikey and Paulz like this.
  6. Paulz
    Paulz
    Air cured Cerakote works for me.
    hrm2k and mad mikey like this.
  7. hrm2k
    hrm2k
    and you spelled it correctly. I remembered the curing process was not quick and took a guess at the name.
    Thanks for setting that straight
  8. Rickybop
    Rickybop
    I haven't had the chance to use it yet, but I've been doing research and it sounds like the high temperature cerakote waaaaay out performs any other DIY "high temperature" coatings. I'm seriously considering it for my exhaust as well as other components.
  9. Bandit Billy
    Bandit Billy
    Ceramic coat on 4 of my current cars headers. Coated inside and out. Look nice, easy clean up. They claim cooler running temps, all I know is they look cooler.
    Budget36 and SS327 like this.
  10. jimmy six
    jimmy six
    My Y-block cast iron exhaust manifolds are coated with the brush on product from Eastwood and they have looked good for 11 years. My sons original Nicson’s have had the same. IMG_2576.jpeg IMG_3246.jpeg IMG_4522.jpeg
    Budget36 and olscrounger like this.
  11. primed34
    primed34
    I've used both Eastwood and Por 15 with good results. Where I screwed up was not going back over the manifolds with something to clean them better after media blasting them.
  12. 6sally6
    6sally6
  13. bobss396
    bobss396
    I used POR15 spray paint on mine. Baked in the oven at 400F per the instructions. After 6 years, still holding up fairly well. I cleaned them up with a grinder and media blasted them first.
  14. 34Phil
    34Phil
    get one you have to bake on, then wait for a day you have the house to yourself. You will still get caught, but it won't be as bad as it was.
    Budget36 likes this.
  15. Budget36
    Budget36
    Dang Phil, get with it. We’re getting into the 2020’s pretty much now. Don’t tell me you do NOT have an oven out in the shop;)
  16. hepme
    hepme
    cheap way is hi temp BBQ paint available anywhere. It lasts quite a while, not permanent. Did I say cheap?
    partssaloon likes this.
  17. '29 Gizmo
    '29 Gizmo
    from UK
    Depends what they are made from. Cast iron, steel, stainless steel?
