1952-59 Ford Exhaust Manifold/Header Help Needed
Discussion in 'Off Topic Hot Rods & Customs' started by FordFairlane55, Dec 8, 2012.
  1. FordFairlane55
    FordFairlane55
    from Florida
    Just made a down payment on a 351W based engine to be built for my 55 Ford.
    I know many people have done this engine swap, so I am hoping someone has a success story with a vendor/exhaust manifold that will fit.
    I have read the "sticky note", but it appears the author has experience with a 302 - and specifically states the 351W is wider, "which may cause clearance issues".
    I need to know if the header referenced will fit the 1955 with 351W or does someone know what will fit (with the stock suspension & steering box)?
    Thanks
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    The header listed for the 302 has smaller primaries this is actually an advantage when installing a 351W as it will give you more clearance by the steering box,smaller primaries are better for low end torque and economy so for a cruiser it's a win-win.
  3. FordFairlane55
    FordFairlane55
    from Florida
    Thanks Jeff.
    At least I now know one standard production option.
    I know building my own or having a pair made is another, but don't want to deal with that if I can avoid it.
    I will check with the builder on the port size. It is a Dart block with Edelbrock heads, producing 425+ hp (won't know exact until built/dynoed), so I don't want the exhaust to be too restrictive.
    Anyone done this and found anything else on the market or had something made by a vendor?
