Technical Exhaust manifolds
Discussion in 'The Hokey Ass Message Board' started by mikhett, Jun 11, 2024.
  1. mikhett
    mikhett
    from jackson nj
    How are you guys restoring x manifolds? Powder coat,hi heat paint sandblast then calyx?Thanks
    Sharpone likes this.
  2. squirrel
    I just leave the rust on them, they look so natural that way!
  3. jimmy six
    jimmy six
    I blasted and coated mine with Eastwood exhaust manifold paint with a brush… they look natural to me and have stayed the same for 12 years. The shiny silver coatings are just a little too much for me. IMG_5805.jpeg
  4. Dan Hay
    Dan Hay
    VHT header paint but they need a redo periodically.
  5. 05snopro440
    05snopro440
    Gl*** bead and VHT header paint. Works pretty good.
  6. Bandit Billy
    Bandit Billy
    I don't have anything with manifolds other than the daily's but I used this on my Vette when I had it. Rub it in with a rag (wear gloves, it's anti seize, quite messy).
    Lasts a year or more, no overspray, no masking. I use it on M/C and cast water pumps to make them look fresh. That little tub will last for years.
    Sharpone and jimmy six like this.
  7. Blake 27
    Blake 27
    These Sanderson exhaust manifolds were smoothed and re-ceramic coated.
  8. deathrowdave
    deathrowdave
    from NKy
    There is a business in Harrison , Oh . . That blasts and coats exhaust manifolds . They do lots of work for Uncle Sugar .
    Their work is the best I have ever seen , my Buddy had his done for his early Vette . Look as good as the day they were finished . Perfect dark gray in color .
  9. okiedokie
    okiedokie
    from Ok
    A7771B7F-BC26-4F76-9329-629C454C4147.jpeg I have had success with Spray Graphite. Blaster Graphite Dry Lube specifically. Works on cast items that you don’t want to paint. These were done maybe 2000 miles ago.
    jimmy six likes this.
  10. marvbarrish
    marvbarrish
    from SoCal
    I recommend a high temp ceramic coating.
  11. 6sally6
    6sally6
    POR-15 makes a manifold paint that works pretty good. Brush it on right over the rust !
    Follow the instructions.....(does ANYBODY REALLY do that?) and it will hold up for years.
    6sally6
    mitch 36, jimmy six and CSPIDY like this.
  12. Joe H
    Joe H
  13. mitch 36
    mitch 36
    Like 6sally6 said, POR15... I used it on the manifold on my 250 engine about 15 years ago and it's still hanging in there. Mitch
