Technical Exhaust pipe end for Rams Horn
Discussion in 'The Hokey Ass Message Board' started by Truckedup, Aug 25, 2015.
  1. Truckedup
    Truckedup
    I have a SBC with 2 inch out Rams Horn exhaust manifolds. I 'm fabricating an exhaust and need the pipe end shaped to hold the exhaust donuts. I have made these in the past but just wondering if there's a place I can buy a short length to weld on my pipes. Local exhaust shops around me don't do this sort of stuff. thanks
  2. czuch az
    czuch az
    Maybe junk yard and cut one off an existing pipe.
    That might be a*****shoot up there with the longevity of exaust and all, just the best I can come up with.
  3. You should be able to get the flange and takeoff pipe from Walker.
    It might be listed by dimension for universal fit. It might be listed by application as well.
  4. BobF
    BobF
    from Poway, CA
    Find a friend who works in a muffler shop with a pipe bender machine, or a shop with one. They can take the pipe and clamp it in, pull a couple levers and it folds a ridge in the pipe to slide the donut on. That's how I had mine done.
  5. Truckedup
    Truckedup
  6. Truckedup
    Truckedup
    The muffler shops in town say we don't do that or the guy who does that isn't here.Nothing any good in junkyards that would be like what I need.......I looked here at Walker parts and don't see them http://www.walkerexhaust.com/assets/downloads/english/Walker_Hardware_Accessories.pdf
    last time I fabricated donut stops from 3/16 rod bent into a circle and then welded onto the the pipe.It worked out ok ,I just looking for a different way to do it...
  7. tommy
    tommy
    When I first started out, my used machine didn't have a flaring tool. I'd cut the flares off of a Y pipe and welded them on. The manifold ends of a Y pipe are so hot that they never rust out. Finding a used rusty Y pipe could be a problem today.
  8. What about flairing a pipe, cutting off the flaired part, sliding it over another piece of pipe and welding it together. That way you'll have the flaired part for the doughnut and the straight pipe to keep it centered
    tb33anda3rd likes this.
  9. BigDogSS
    BigDogSS
    from SoCal
    I've seen short exhaust pipe pieces at Pep Boys and other parts stores.
  10. paul55
    paul55
    from michigan
  11. LMFAO ( sorry about that) I usually have half a dozen head pipes just setting around and could have sent you some with torque flanges just cleaned that stuff out last year.
    I'll bet if you get a JC Whitney catalog you can still buy head pipes for a chevy and just cut off what you don't need.
  12. flatheadpete
    flatheadpete
    from Burton, MI
  13. Truckedup
    Truckedup
    Well Well, I have a press and like a proper hillbilly I got trailer balls....Thanks for the tip
    *******, that's ok, I cleaned out last year and threw out an old Chevy truck y pipe...
  14. Tony
    Tony
    Trucked up, a friend of mine has a bender at his home shop on Rt 31 in Spencerport.
    If you cant find what you need let me know and i'll pm you his info.
    Pretty sure he can make whatever you may need and he's got many many years experience.
    Tony
  15. Rusty O'Toole
    Rusty O'Toole
    What kind of******** muffler shops you got. Around here they don't mind making $10 bucks for 2 minutes work. See if you can find a small one man shop. The big chains don't want to know.
    INVISIBLEKID likes this.
  16. Its catch 22, I get feeling crowded and can't seem to throw anything out and as soon as I do up jumps the devil. Damned if I do damned if I don't. :D
    I am cleaning and rearranging today ( and the next week or two) if I run across something its yours. ;)
  17. Truckedup
    Truckedup
    Thanks, I'll let you know..
  18. paul55
    paul55
    from michigan
    Can't take credit, saw it here and saved the pic to send to a buddy, who wanted to flare some injector stacks.
  19. blue 49
    blue 49
    from Iowa
    Might not be the right way to do it, but I just made flat flanges to bolt to the manifold and welded my pipes to them. I made gaskets from header gasket material and it works fine.
    Gary
  20. studebaker46
    studebaker46
    go to napa check out the head pipe from 61-64 chev car with a small block
  21. stimpy
    stimpy
  22. stimpy
    stimpy
    oh I forgot to mention change to a 3 bolt flange ...
