1952-59 Ford exhaust smell
Discussion in 'Off Topic Hot Rods & Customs' started by squire g, Jul 7, 2018.
  1. squire g
    squire g
    i have recently been getting bad exhaust smell in the car. i had it checked and no leaks. does anybody else have this problem. or had this problem and fixed it? its at point that my clothes reak of exhaust when i get out. im sure my interior will need a good shampoo soon also.
  2. 56longroof
    56longroof
    Station wagon? If so check the sending unit gasket on top of the tank. Also make sure your gas cap is the old vented style. If not you will have this problem over and over. The new vented gas caps are only allowed to vent one way due to EPA regulations. The wagon gas caps are different than the sedans because there is no tank vent. I had to drill a small hole in my cap to alleviate this problem. I dropped the tank in mine twice before I found out this info.
  3. 56longroof
    56longroof
    One last thing. How is your exhaust ran out the back? I had to have mine changed to exit out the sides. That and the tank fix took all the smell from inside my car.
  4. squire g
    squire g
    dual pipes straight out the back and pointed down even with the bumper. nothing fancy. i dont get why faulty fuel tank components would produce exhaust smells. but i have the original cap and sending unit.
  5. okiedokie
    okiedokie
    from Ok
    I kind of remember that the reason for station wagon exhaust exiting to the rear corners was to alleviate exhaust odor.
  6. 56longroof
    56longroof
    I misread you original post. I skimmed through it and thought gas smell. If the smell is that strong then you have a leak you haven't found or it is coming in from the back. I had both and it was bad. I just had a new system put on my car and it's so much better. No smell whatsoever.
  7. Old Rod
    Old Rod
    from Brazil, IN
    I have a repo cap on my Wagon and have some gas smell. Did you drill the hole thru entire cap?
  8. 56longroof
    56longroof
    Yes. If I remember I'll get a quick pick for you.
