Exotic Metal DooDads
Discussion in 'The Hokey Ass Message Board' started by Stutz, Apr 26, 2007.
  1. Stutz
    Stutz
    Hey Gang, I am in the process of finishing a custom aluminum gas pedal and a copper brake pedal which I plan to post when I finish. The aluminum isnt to exotic but I was curious what other trinkets and doodads people have made out of exotic metals like copper and br***, ect., that your using in your cars/bikes. pedals, knobs, ect. lets see some pictures.
    Stutz
  2. Track-T
    Track-T
    Not a large item,Made my carb linkage from br*** rod and aluminum,
    Because of body channel I needed a 2" drop from motor to firewall.
  3. treb11
    treb11
    better pray that br*** (soft) doesn't bend under compression and hang your carb wide open. Better to use Stainless rod.
  4. scootermcrad
    scootermcrad
    Cool thread! Would like to see the same... BTTT
  5. SUHRsc
    SUHRsc
    i made this winged V8 emblem out of copper
  6. Track-T
    Track-T
    SUHRsc, That way cool my friend, You did a great job.
    Didn't use "soft br***" on the linkage,It's a type of hardened br*** that
    we use making signs.
  7. draggin ass
    draggin ass
    from hell
    im using a ***anium punched sheet metal insert for my cars grill. ill post pictures when i get the "go ahead" from my boss to take the s**** ***anium from work... i gotta pay the s**** price for it.... im also trying to get some 3/8 ***anium coils for making oil coolers or trans coolers out of the remote oil cans.
  8. rev383
    rev383
    Cool parts!
    All carb linkages should fail in the closed position and have 2 springs! I like the 2 spring GM set up found at the quick pics in most auto parts stores.
    70/30 comp br*** is pretty darn strong. We used a lot of br*** rod for boiler controls and systems and it held up very well in some very bad enviros. A36 is the most common structural steel and 70/30 br*** is at least 70% as strong.
    And yes, it is hard to beat cold rolled stainless for strength!
    Something to compare other metals to:
    Some typical tensile strengths of some materials:
    <TABLE cellSpacing=0 cellPadding=2 border=1><TBODY><TR><TH>Material</TH><TH>Yield strength
    (MPa)</TH><TH>Ultimate strength
    (MPa)</TH><TH>Density
    (g/cm<SUP>3</SUP>)</TH></TR><TR><TD>Structural steel ASTM A36 steel</TD><TD>250</TD><TD>400</TD><TD>7.8</TD></TR><TR><TD>Steel, API 5L X65 (Fikret Mert Veral)</TD><TD>448</TD><TD>531</TD><TD>7.8</TD></TR><TR><TD>Steel, high strength alloy ASTM A514</TD><TD>690</TD><TD>760</TD><TD>7.8</TD></TR><TR><TD>Steel, prestressing strands</TD><TD>1650</TD><TD>1860</TD><TD>7.8</TD></TR><TR><TD>Steel Wire</TD><TD> </TD><TD> </TD><TD>7.8</TD></TR><TR><TD>Steel, Piano wire</TD><TD>c. 2000</TD><TD> </TD><TD>7.8</TD></TR><TR><TD>High density polyethylene (HDPE)</TD><TD>26-33</TD><TD>37</TD><TD>0.95</TD></TR><TR><TD>Polypropylene</TD><TD>12-43</TD><TD>19.7-80</TD><TD>0.91</TD></TR><TR><TD>Stainless steel AISI 302 - Cold-rolled</TD><TD>520</TD><TD>860</TD><TD> </TD></TR><TR><TD>Cast iron 4.5% C, ASTM A-48</TD><TD>276 (??)</TD><TD>200</TD><TD> </TD></TR><TR><TD>***anium Alloy (6% Al, 4% V)</TD><TD>830</TD><TD>900</TD><TD>4.51</TD></TR><TR><TD>Aluminum Alloy 2014-T6</TD><TD>400</TD><TD>455</TD><TD>2.7</TD></TR><TR><TD>Copper 99.9% Cu</TD><TD>70</TD><TD>220</TD><TD>8.92</TD></TR><TR><TD>Cupronickel 10% Ni, 1.6% Fe, 1% Mn, balance Cu</TD><TD>130</TD><TD>350</TD><TD>8.94</TD></TR><TR><TD>Br***</TD><TD>approx. 180+</TD><TD>250</TD><TD> ;</TD></TR></TBODY></TABLE>
  9. Slag Kustom
    Slag Kustom
    due to my race care up bringing i use exotic metals where ever i can. radiator rods made from ***anium, most bolls and nuts are ***anium. I look for left over s**** to make most parts out of. I have an argon chamber set up to weld the ***anium in. it takes a good polish and is not that much to buy and almost 2 times lighter then stainless.
  10. draggin ass
    draggin ass
    from hell
    you don't need a chamber to weld ***anium. ill tell you since i weld ***anium all day everyday...(mostly heat exchangers, or parts racks for the plating industry) all you need is to purge the area you are welding front and back, weld only 5/8ths of an inch at a time. set your rear purge to always be on(you might need a dual feed regulator on your tank) then on your tig welder set your after purge time to 20 seconds, more if its really thick. also use a big purge cup. we use 12s at work.
    ok ill run through it- tack your piece together, strike an arch and hold it till it melts.. dip dip dip ect ect.. you know the drill(just like steel), then after about 5/8ths an inch stop and let off the pedal fast but not all the way, let the arch stay super small for about 2 seconds* so it wont "crater" then let off completely holding the torch still. youll see the metal harden 2 times* once is the metal becoming mostly solid again, then it kindof completely hardens. its easy to see the metal first harden, but the second time is almost like a shadow flying over the metal. when that happens the second time count to about 3 and pull the torch away.
    if you do not purge the weld it will come out blue mostly or red or purple. if it does you didnt purge it long enuff or not at all. when its not purged it becomes contaminated and looses its tensile strength. and can break and be susceptible to corrosion. if its welded right the weld will look silver! and there will be no color anywhere.
    hope that helps.
