Hot Rods Experience with Zipps water pump riser setup?
Discussion in 'The Hokey Ass Message Board' started by txcr13, Oct 27, 2016.
  1. txcr13
    txcr13
    Not sure whether or not I will use a Zipps water pump riser setup on my Gen 1 406 SBC. I see that the water pump recommended for use with the SBC riser is one designed for use on a six cylinder engine.
    Does anyone have experience with this setup? Does the six cylinder water pump flow enough for this engine?
    I know there are lots of other variables to cooling the engine, but it is just the riser and water pump setup I do not know enough about.
    Any help will be appreciated.
  2. They work.
    harpo1313 likes this.
  3. gimpyshotrods
    gimpyshotrods
    Indeed they do.
  4. deucendude
    deucendude
    from norcal
    They work great. All my 32s have them. Except the banger. Simple with a engine driven fan and never needed a electric fan. Not even in 100+ traffic.
  5. ace5043
    ace5043
    from Florida
  6. 19Eddy30
    19Eddy30
    from VA
    Work great , I found out the trick to get all air out of system
    ( I drilled the riser Wright on top near pump & installed a air bleed & drilled a hole in thermostat 1/8 )
    Is to take the Thermostat & housing off,
    Fill block threw intake, let set about 10 mints ,then repeat as needed,
    Install thermostat & housing ,
    Top off Radator crack air bleed until anti-freeze pee's out , Tighten bleed screw
    Start up , done !!!
    I chased a over heating problem for a mouth until I did this,
    Run's 180 , its a cheap $135 Aluminum Ebay Radator for 32 ,
    motor is 11-5.1 Compression on street
    I tried vacuum down way , did not work.
  7. Chucky
    Chucky
  8. manyolcars
    manyolcars
    What makes the aluminum pump better than the iron pump?
  9. Chucky
    Chucky
    On a cooling and cost aspect, nothing. But it would be less weight and you wouldn't need to paint it. I just thought it was interesting that it is even produced in aluminum. It also says "heavy duty" in the description??? Maybe that's just referring to the price?
    Tman likes this.
  10. harley rider
    harley rider
    use it. they work great.
  11. wayne-o
    wayne-o
    They work like a champ. I had some minor overheat issues at first, bought a high price flowcooler pump, no change. Went back to the stock 6 cyl pump. Built a shroud and cannot get over 180 even in 100 deg stop and go traffic.
  12. Chuck Craig
    Chuck Craig
    from Ocala FL
    The Autozone pump that I purchased also had the disc mounted to the back of the impeller, much like the flow cooler model.
  13. dirty old man
    dirty old man
    Same here and absolutely no problems if you use the bleeder and byp*** hose as shown in instructions, and I also drilled holes in thermostat.
  14. Turbo26T
    Turbo26T
    Quick question about using Zipps waterpump riser ..What pulley setup do you use ? ( Crank , w/pump etc..)
    Short pump or long pump type ?? I know it uses a 6 cyl w/pump....but I'm ready to order pulleys , and most specify V8 short or long pump..
    DOH !!!
    Just went to Zips site and downloaded install instructions and it specifies the pulleys.
    Thanks
    Stan
  15. HOTRODPRIMER
    HOTRODPRIMER
    So far I have used 6 Zip's riser's and the impeller is basically the same size a the sbc just the housing is different. HRP
  16. mgtstumpy
    mgtstumpy
    Snow white pump is an alternative. I've not used either and have no affiliation with anyone but here are the instructions for both, bleeding is the key. Here is a HAMB link to valve
  17. pat59
    pat59
    I'm having trouble finding a waterneck to work with the Zipps. Any Zipps Tipps? :)
  18. 19Eddy30
    19Eddy30
    from VA
    use short water pump pulley combination ,,
    medium pump combination or long water pump whatever fits your needs
    They make nice aluminum thermostat housing , straight out the top ,45 & 90s ..
    they swivel for $25-$30
  19. txcr13
    txcr13
    Thanks, gents, for all the helpful replies. Much appreciated.
    A follow up question...what size fan, and how many blades were you guys using on 350 c.I. and larger engines?
    Thanks again!
  20. gimpyshotrods
    gimpyshotrods
    As big as will fit, not hit anything, or go past the edges of the core.
    Lots of blades.
  21. dirty old man
    dirty old man
    ^^^^^^^^^^^^^^^^^X2
  22. HOTRODPRIMER
    HOTRODPRIMER
    Straight up aftermarket or Murray # 277689 (54-72 GMC & Chevy light trucks) thermostat housing.
    I run this all steel fan from Summit, it's 17" and does a excellent job, HRP
    Chucky likes this.
  23. A Boner
    A Boner
    What is the simplest way of installing the byp*** hose when running a heater. My heater has a ball valve shutoff that is under the dash. Should say SBC/Zips.
  24. A Boner
    A Boner
  25. dirty old man
    dirty old man
    If you have a set up to shut off the water flow thru the heater in warmer weather, then you'd need to plumb in enough valves and hoses so that when you blocked off the flow of coolant thru the neater, it was free to byp*** the heater and still flow enough thru a byp*** to serve the purpose of a flow past the thermostat of some coolant when the thermostat was closed. Otherwise you mat get a steam pocket because the byp*** built into a stock WP is eliminated with the Zip's Riser installed
  26. 325w
    325w
    Well , on my zips set up I just didn't want to run a hose over to the left head. So I ran the hose back to the intake heater fitting. So far no known issues. Have seen some where the water pump fitting was capped and no issues. Used the Dorman brand bleeder fitting on the pump housing.
  27. BuiltFerComfort
    BuiltFerComfort
    Do they make something like this for SBF or is it SBC only?
  28. HOTRODPRIMER
    HOTRODPRIMER
    Zips doesn't but Snow White does. HRP
  29. HOTRODPRIMER
    HOTRODPRIMER
    Mine has been like that for close to 29 years. HRP
  30. A Boner
    A Boner
    So can I run the hose off the 6 cyl pump, to a Tee, from the Tee run one hose to the intake manifold, and the second hose to under the dash to the shut off valve and then to the heater? Would I also have to slightly restrict the hose from the Tee to the manifold to the size of the byp*** hole in the sbc block? The Tee would be a 5/8".
