Hot Rods Experience with Zipps water pump riser setup?
Discussion in 'The Hokey Ass Message Board' started by txcr13, Oct 27, 2016.
  1. bjinx
    bjinx
    Go up to the search ****on and type in "Zipps water pump riser". Three pages of post relating to this product going back to 2007 will come up. You will find the answer to any question you might have. Deuce Roadster, may he rest in peace, contributed to a lot of the, Zipp Riser threads with excellent tech post.
  2. dirty old man
    dirty old man
    ^^^^^^^^^^^ X2 on Deuce Roadster tech help, and his p***ing was a real loss for hot rodding and HAMB.I agree that a byp*** hose of a smaller size between intake and waterpump should work. But then where will you hook up heater hoses?
    Also what is all this stuff about a hose to left head? My heads have a threaded and plugged outlet between #6 & #8. I just put a street el there and ran hose to heater hose inlet hole on water pump.
    HRP , I can only see the water pump end of hose in your pic. Where is the other end hooked in?
  3. A Boner
    A Boner
    Is there a detailed diagram that shows the direction coolant flows through a SBC?
  4. lrs30
    lrs30
    from Kentucky
    I have one on my soon to be drivable gl*** 3 window with a sbc in it, do you happen to have any part numbers for radiator hoses by chance?
