Technical Experienced engine builders of SBC’s - need your advice!
Discussion in 'The Hokey Ass Message Board' started by McMac 31, May 30, 2025.
  1. 2OLD2FAST
    2OLD2FAST
    from illinois
    I meant the seal surface , sorry ...
  2. FrozenMerc
    FrozenMerc
    We need to have a discussion about tool tolerances. Your torque wrench (assuming generic clicker style) probably on it's best day will have about a +/- 5 ft-lbs swing. In other words, set the thing at 73 ft-lbs, and you will probably have one bolt at 78, another at 68, and the rest some where in between.
    On top of that, torque is a really, really shitty way to estimate what we really want to control and that is the clamp load generated by tightening the bolt. Very small changes in surface finish, coating, manufacturing tolerances, lubrication, etc can produce dramatic swings in clamp load just due to the way that friction between the bolt and threads is affected.
    In other words, don't get too hung up on 5 ft-lbs.
  3. 19Eddy30
    19Eddy30
    from VA
    Growing up @ a track Drag & Round
    In pit's seen & done many fix's ,
    Seen several times Crank polishing
    With sometimes cranks in block , cylinder honing ,
    Farm fix , even drill bits for missing rollers in bearings .
  4. big john d
    big john d
    from ma
    if you go to a nhra national event you can check your torque wrench at the arp tent display
    McMac 31 likes this.
