Technical explain why?
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Jan 14, 2017.
  1. tb33anda3rd
    tb33anda3rd
    why would the previous owner wire this like this? loops with wires weaved in and out. the wires in the loop i am holding are attached at both ends. fortunately he never finished the engine and headlight connections so at least i didn't have to disconnect the whole harness:rolleyes: DSCF0001.JPG DSCF0007.JPG
  2. Dirty Dug
    Dirty Dug
    Perhaps it was done before wire cutters were invented?
    49ratfink, OahuEli, 41 C28 and 5 others like this.
  3. Jerrybigbird
    Jerrybigbird
    from Montana
  4. HOTRODPRIMER
    HOTRODPRIMER
    Prime example of a sever lack of reading and comprehension skills,that or he had lunch here and forgot about wiring. :D HRP
  5. bct
    bct
    Better than too short i guess.
    46international and tb33anda3rd like this.
  6. Stogy
    Stogy
    Electro Spaghetti...Mama Mia...:eek: Hand them a broom with no bristles time...wherever they are...ahhhh projects...Yours to discover...;)
    tb33anda3rd and Max Gearhead like this.
  7. Raiman1959
    Raiman1959
    That is a mess!....I can only imagine the 3 stooges wiring the horn ****on, each with a spool of wire, and constant poking fingers in the eyes!
  8. 41woodie
    41woodie
    He was being paid by the foot
    30tudor, LOU WELLS, timwhit and 5 others like this.
  9. Some folks care deeply, as to how they do ANY job, others simply "don't give a ****".
    Unfortunately, you have a "don't give a ****" P.O.
  10. Montana1
    Montana1
    I hate wiring... :mad::rolleyes::D
    The37Kid, 302GMC and timwhit like this.
  11. wbrw32
    wbrw32
    He was trying to follow "ALL" the instructions he received from posting the question on the HAMB message board..
  12. Mr48chev
    I think I have followed behind that guy before.
    I'd say it is the "this is what they gave me I need to use it all' syndrome rather than t******* each wire to fit and running the wires in an orderly fashion. If you want neat wiring make friends with a guy who has worked for the phone company for years. I have a friend who worked for the phone company for 30+ years and his work was so neat it blows your mind. When he retired from the Phone company he also retired from wiring cars for guys much to the chagrin of a lot of guys in the PNW.
    tb33anda3rd and volvobrynk like this.
  13. Texas57
    Texas57
  14. gene-koning
    gene-koning
    Obviously, you have never untapped a wiring harness from a late 1980s-2000 factory harness, have you? Most factory harnesses I've untapped looked much the same. The wires wrap around each other, and some timed double back 2-3 times over the course of the harness.
    Who ever wired that car probably has untapped a factory harness, and concluded it was proper for it to be that way. Gene
    K13, tb33anda3rd and volvobrynk like this.
  15. Texas57
    Texas57
    OK....before I get ripped a new AH........that was a gag photo. I had a bunch of oem wires I had pulled from a van just in case I needed a specific color/gage I couldn't get. I stuffed one end out the dash opening and wrapped the other end around my neck. The only actual wires in the photo are the 1/2 dozen loops. With that said, it's easy to understand how somebody could get frustrated. This photo below is the real thing, and none of it is ch***is wiring. engine wiring 001.JPG
    upspirate, tb33anda3rd, Stogy and 2 others like this.
  16. That **** happens!
    All the time :
    - when wire without a plan,
    - when Run one wire at a time
    - when start at the wrong end
    - when transplant harness
    -when make your own kit
    - when the dog ate the directions. Or the kit was bought 5 years ago and lost them
    - drink tequila and listen to ribbon dance music
    - dizzy from blood rushing to head
    - have never had to troubleshoot an electrical problem.
    - bunch it together in a harness then hook it up so you just have to do it once. Explains factory harness cluster ****
    Pick one or invent another :D
    clunker, Texas57, LOU WELLS and 2 others like this.
  17. wojojo
    wojojo
  18. LOST ANGEL
    LOST ANGEL
  19. 2935ford
    2935ford
    Because he could!:)
    tb33anda3rd likes this.
  20. gnichols
    gnichols
    from Tampa, FL
    Ever see how commercial electricians wire your house before the dry wall goes on? It may be safe, but it isn't "sanitary" by any means. Gary
  21. tb33anda3rd
    tb33anda3rd
    i started to clean it up and untangle the mess. the wires are all marked and i already found some that went to the wrong place. i was working on my back, bent over and twisted, thinking they were just tucked up under and when i pulled the front wires through it would neaten up. then i came to the conclusion the dash and all the wiring needed to be removed to do the job.
    funny @gnichols, the guy is a licensed electrician.............
    maybe he grabbed the Karmasutra instead of the instruction book?
  22. Those poor electrons.... They will come out the end of those wires all dizzy....
  23. I think you want the wires all the length, that way the 'lectric will get to the lights the same time...this way the left head light won't come on before the right tail light!
    Montana1, oldsjoe, Texas57 and 2 others like this.
  24. 4wd1936
    4wd1936
    from NY
    I see this all the time. It is amazing how many really nice cars have hidden wiring that looks like that. I call them 90% cars, it's like the builder got close to the end and just got tired and sloppy. The sad thing is that some are also dangerous i.e. power windows with no relays and the same with high amp lights. I have seen them come from pro-builders like that also but fortunately not often.
    lothiandon1940 and tb33anda3rd like this.
  25. tb33anda3rd
    tb33anda3rd
    i will post photos of how i fixed this........
  26. Hey Moe, here's a pipe, but it's full of wires! Well, drag them wires outa there and bring that pipe over here!....
  27. chevy57dude
    chevy57dude
    What's the problem?
    41 C28, 302GMC, tb33anda3rd and 2 others like this.
  28. Ed Angel
    Ed Angel
    Jeep owners ! [emoji33]
    To do good wiring takes time to do great wiring is an art .
    Sent from the frozen North
  29. upspirate
    upspirate
  30. upspirate
    upspirate
    After...I know ,I know, zip ties and split plastic looms !!!!
    The dash can be removed with it's harness intact by disconnecting from the terminal strip....the wires are coded so no problem putting them back correctly.
    Montana1 and tb33anda3rd like this.
