explorer rear end
Discussion in 'The Hokey Ass Message Board' started by banditomerc, Apr 22, 2009.
  1. banditomerc
    banditomerc
    So...is there a tag on the explorer rear that clearly has the gear ratio on it ?
  2. jr9162
    jr9162
    Can the axles and rotors be re-drilled for Buick 5 on 5" lug pattern?
  3. coryw
    coryw
    from Omaha, NE
    There is a typically a tag bolted on with the rear cover, if that isn't legible then I think you'll end up having to pull the cover and counting teeth. From your original post I think that may be where you're at. Sorry.
  4. 35PontiacCoupe
    35PontiacCoupe
    from COS
    I thought you had the tag all figured out, no? The 5L73888H31 tag is the one you want. That 5 is probably a 3L73, which makes it 3.73. That's what my exploder had in it, but there are clearly more options...
    The explorer rears have the bigger 31 spline axles and are much beefier than the ranger/mustang axles of the same era. FWIW, but I think that's been covered too.
  5. 35PontiacCoupe
    35PontiacCoupe
    from COS
    I couldn't tell you for sure without looking at the axle flange, but I would imagine that you'd be able to go up that little bit. Mine are all mounted up, so I can't see the flange, but maybe someone else out there can help!
  6. Hal_396
    Hal_396
    I had mine redrilled for a 5 x 4 3/4 pattern . I would say your 5 x 5 would not be a problem. I sent the axles to Moser's and had them do it.
  7. jr9162
    jr9162
    I reckon you had Moser redrill the rotors too?
  8. I am looking for a 3.27 geared limited slip exploder rear end. They are hard to find!
  9. TomP64
    TomP64
    from Vancouver
    Many Exploders are 3.73 with the L/S, they have a second tag telling you to to use 75W140 synthetic on the TracLok ones.
    They are all offset to the right. I use two right axles and shorten the left side of the housing to make them centered.
    No need to weld the tubes unless you are building an eight second race car. Don't do any welding on any rear end unless you have a jig to ***ure the thing is straight.
  10. fridaynitedrags
    fridaynitedrags
    Posted by TomP64....
    "Don't do any welding on any rear end unless you have a jig to ***ure the thing is straight."
    Excellent advice. :D Ask me how I know. :eek:<!-- / message -->
  11. Hal_396
    Hal_396
    I drilled the drums! :p
  12. H3O
    H3O
    depends on how tall of tire you're gonna run.
  13. FoMoCoPower
    FoMoCoPower
    ONLY the `95-up ones had the 31-spline.
  14. FoMoCoPower
    FoMoCoPower
    Yes,just as long as nobody removed it. And it`s soooooo simple to read.
  15. FoMoCoPower
    FoMoCoPower
    Well I have seen dozens of them,and have bought/re-sold several,you see...they are a popular swap for the Jeep Cherokee/Wrangler.
  16. Crease
    Crease
    I agree, the TH350 is a fine ******, but even with 3.55s my little coupe SCREAMS!
  17. banditomerc
    banditomerc
    If i run 670x15(27" tall) fiestones,and use the 350 trans with the explorer 373 geared rear....what rpms am i looking at say going 60 mph?
