Extended clamping vice grips
Discussion in 'The Hokey Ass Message Board' started by Danshotrod, Sep 19, 2012.
  1. Danshotrod
    Danshotrod
    Got three of these griping plyers at HF $4.50 each extened them 6 inches using 3/16 x 3/4 stock. Works great make them as long as you want..Better then paying $25. each...Dan
  2. Brad54
    Brad54
    from Atl Ga
    You know, that's a damn good idea.
    I had a couple of smaller Chinese clamps, without the swivel pads on each end, and they wouldn't hold well. Not sure what the problem was, but they would unclamp after a while... they never really "clicked" into the locked position, they sort of mushed into lock, and would then come undone.
    I don't know if the new HF ones would be any different... but they'd definitely have more bite with that swivel pad, and extending them like that is perfect.
    I'll be getting a few and doing exactly what you've done.
    Thanks!
    -Brad
  3. Rocky
    Rocky
    Classified Editor
    I did the same thing with mine only I made 'em 16 inches long...made them for some special job I was doing....I think it was welding 2, 61 chevy pickup fenders together to make 1 good one
  4. putz
    putz
    from wisc.
    great ideal ! thank you
  5. 383deuce
    383deuce
    Now this I like......Going to get some and do this one...Thanks
  6. Mr48chev
    Not a bad Idea and they are cheap enough that you don't mind cutting them up to make special tools out of them. I've got some cheap long reach ones that are ok for holding tin together to weld it but not much good if you really have to clamp down on anything.
  7. I can't get the harbor freight clamps to stay straight.
    The clamp wants to roll and and the tips try to p*** each other.
  8. b-body-bob
    b-body-bob
    Good idea. I need some extended the other direction, wider not longer.
    I agree on the ones without the swivel pads not clamping. They basically **** IMO.
  9. 1950heavymetal
    1950heavymetal
    good idea, thanks for sharing.
  10. chopolds
    chopolds
    from howell, nj
    I've got one set of those CHinese clamps, and they don't stay clamped. Nothing worse than tools that dont' work!
  11. R Pope
    R Pope
    If they don't say Vise Grip on them, I leave 'em in the store.
  12. onedge
    onedge
    handy. i havent tried those HF swivel pad type yet.
  13. brokenspoke
    brokenspoke
    Every Horrable Freight tool I have bought has failed at some point
  14. b-body-bob
    b-body-bob
    I bought some long ones at Tractor Supply, they were branded "Larin" and have swivel pads so they work better than the China Fright ones.
  15. chevy3755
    chevy3755
    very good idea.......may barrow that one
  16. Roger Walling
    Roger Walling
    You would be better off spending your time making up this tool that will work better than any H-F tool. Use wheel nuts that have a conacil end. Stronger and never let you down when you are just about to weld.
  17. TR Waters
    TR Waters
    from Vermont
    By the time you buy that cheap junk and modify it, you will be ahead to buy the good ones.
  18. Don's Hot Rods
    Don's Hot Rods
    from florida
    We have a bunch of Vice Grip brand and also HF (Pittsburgh) brand clamps and there is a difference in the quality and the way the screw goes in and out. But the HF's are good for clamping in areas where they are going to get overheated or otherwise damaged in the welding process.
    Don
  19. Kerrynzl
    Kerrynzl
    Extend it with 2 pieces of Square Tubing.
    Slot the ends with a cut-off wheel ,slip the clamps in and weld
    Works great.
    To all you haters of cheap tools [including me:D]
    Cheap tools have allowed me to customise them for 1-off situations which sometimes work better than expensive brand name tools
  20. hoggyrubber
    hoggyrubber
    i can kick myself for not buying some of the nicer extended ones at a auction several years back. one thing about it you don't have much to lose choppin on those cheap ones. hey, if it works, laugh all the way to the bank. if they bite the dust the first time, get the good ones.
  21. Jim Stabe
    Jim Stabe
    I did a similar thing but used 2 pieces of 1/8" strap, it made them a little more twist resistant. I also made up some with a big "U" shape on the top are to go around the rockers to weld in floor pans - don't have a picture of those because I lent them to a friend to do his floors. You can also make crossed arms and have a spreader - not my picture but a good idea.
  22. ago
    ago
    from pgh. pa.
    I never wan't to buy Chinese tools again. Id' rather buy used USA at a swap meet.
    Ago
  23. manyolcars
    manyolcars
    I like this idea but try again with this word, please---conacil? what are these?
  24. Conical. The unbounded surface formed by the union of all the straight lines that p*** through a fixed point.
    2 letters swapped. Not exactly a huge deal. Spelling is not a prerequisite to participating on the HAMB. I would rather have someone saying something positive and misspelling, than someone who spells correctly yet never contributes anything other than criticism.
  25. Roger Walling
    Roger Walling
    Quote;I like this idea but try again with this word, please---conacil? what are these?"
    It's kind of like a cone, but something more like a fingernail or something like that, or something else.
    Each person should choose their own nuts, preferably some that are not in use for something else. And defiantly not a pair that are being busted by someone!
    By the way, one end of the pivot should be welded to keep the "fingers" aligned.
  26. Roger Walling
    Roger Walling
    Eye halve a spelling chequer
    It came with my pea sea
    It plainly marques four my revue
    Miss steaks eye kin knot sea.
    Eye strike a key and type a word
    And weight four it two say
    Weather eye am wrong oar write
    It shows me strait a weigh.
    As soon as a mist ache is maid
    It nose bee fore two long
    And eye can put the error rite
    Its rare lea ever wrong. Eye have run this poem threw it
    I am shore your pleased two no
    Its letter perfect awl the weigh
    My chequer tolled me sew.
  27. hugh m
    hugh m
    from ct.
    Hate to say it, but that looks like the material lists I get at work....
  28. That's" pee see" smart ***.
    :D
  29. dad-bud
    dad-bud
    Hmmmmmm, cheap **** tools that you know are going to break vs expensive quality tools.
    Guess which one is always going to get bought?
    Cheap **** - it's taking over the world - no one wants it so why does everyone buy it?
    Because it's cheap!!!
    Cheap will always win.
    Ho hum.
  30. Jim Stabe
    Jim Stabe
    If I'm making something that I'm just going to use once, why would I want to cut up an expensive set of Vise Grips?
