Leftover exterior trim, damaged sections cut out. Polished and added GM panel rivets. End caps for the cut ends robbed from my tool box.
Silver sharpie wipes off with hoppes #9 and a .223 case cuts a clean hole in the vinyl for drilling the rivet holes.
The trim around the white roll & pleat is original interior '54 Ford trim, the piece between the vinyl and the carpet is exterior vinyl top trim. HRP
Snug fit but it needed new arm rests made up anyway so bent some abs sheet and added upholstery and walnut. Much better than having them on the package tray.
